2007 CVT jolt
Old Sep 2, 2016 | 05:50 PM
jdncomz's Avatar
Question 2007 CVT jolt
Hi, I have a 2007 Outlander with a cvt transmission. It has an issue when driving under 25kph where the car jolts when resuming acceleration.
For example, if i slow down for traffic lights taking my foot off the accelerator then foot back on the accelerator, there is an immediate jolt. This only happens up to 25kph.
I have taken to dealership but they cannot fault it.
has anyone else had similar issues?
Old Sep 2, 2016 | 09:07 PM
SERPENTOR's Avatar
Have you changed the transmission fluid if so how long ago and what are you using?
Old Sep 4, 2016 | 06:08 AM
jdncomz's Avatar
yes cvt fluid has been changed. they used j4 fluid.
Old Sep 4, 2016 | 11:11 AM
Sic_Lucky's Avatar
From what I have been reading the 2007 with a 3.0 V6 came with a 6 speed A/T not a CVT. The CVT came with the 2.4L 4 cylinder (I'm 90% sure of that). With that said I think I have the same symptoms on my 07.
When slowing down and accelerating when it shift up to 5th there is a jerk and seems like a transmission slip. It only happens when you decelerate and then accelerate. My 04 lancer does something similar but it's a 4 speed A/T.
The previous owner of my outlander changed the A/T fluid about 25k miles ago. On a sidenote my throttle position sensor has been buzzing when the ignition is on so it may be the TPS causing it to jerk (malfunction). But that's just a theory.
Old Sep 4, 2016 | 03:29 PM
jdncomz's Avatar
Yes I think you are right. I wish I got the V6 one. You issues does sound similar, Mine jolts when decelerating then accelerating usually under 25kph/15mph. I have also suspected the TPS.
I have it booked in to the dealer again, this time they are going to hook it up to a machine to flush it.
Old Sep 5, 2016 | 10:57 PM
jdncomz's Avatar
Okay, I have had it in to the dealership. I suspect they haven't actually flushed it. The fluid on the dipstick is clear, I thought DQ CVT-J1 was green. Can anyone confirm this?
Also they only charged for 5L, can someone confirm if this is the right amount to do a flush?
TIA
Outie_NZ
Jan 25, 2025 05:55 AM
yadriver
Oct 12, 2013 09:04 PM
swnkylaxplyr
May 12, 2008 09:45 AM
mrtn
Jan 3, 2008 04:34 AM
oscar316us
Sep 15, 2007 12:27 PM
