2007 Outlander V6 Radiator replacement
Old Nov 13, 2019 | 03:21 PM
inuvik's Avatar
Originally Posted by 07OutlanderLS
I ordered one, they ran my vin number and said i do not have the tow package from a1auto. i am not sure if i do or not but i have the little tranmission cooler on the left side. I do not have a hitch mounted on the back so i have no clue. Is there a site to tell if i have the tow package or not?
Use this link and paste your VIN after the equals sign then hit enter:
Monroney Sticker
Old Nov 14, 2019 | 11:33 AM
07OutlanderLS's Avatar
Originally Posted by copyboy311
The tow-package info should be either in your VIN or your model number badge (I think it's on the passenger door sill). The difference in size of the tow radiator and the regular one are minimal. The tow radiator could be extra precaution if you're towing max capacities and running the A/C, but like I said, I don't tow anything so I went with the standard radiator as the tow-package radiator was an expensive OEM-only item. I've experienced no ill effects in the 10k miles since.
Do you have the AWD? I got my rad in today i compared them and the after market is just a bit thinner. So you running the ac and everything no issues?
Old Nov 15, 2019 | 09:53 AM
copyboy311's Avatar
Yes, I have all options and AWD. I don't think there's an option mine doesn't have. No problems with the aftermarket no-tow radiator. You could probably tow with the aftermarket radiator too. I'd imagine the tow radiator is just extra insurance for heavy towing.
Old Nov 20, 2019 | 11:29 PM
I got the rad installed it's the non tow package, car is running perfect thus far. Had to replace the filler neck on the rad bc one of the plastic pieces broke off.
Old Nov 21, 2019 | 09:16 AM
copyboy311's Avatar
I also had to replace the filler neck on the previous radiator and reused it on the new one. Seems to be a common issue that they get brittle with age.
Old Jan 24, 2023 | 05:46 PM
mdevos's Avatar
Hi. I’m wondering if anyone has solution to this. My grandpa has the radiator with the special sensor and will not spend that much money for a new one. I was wondering how you can bypass the sensor. I’ve read it’s difficult but I’m sure someone has figure it out. If any one has any insight or ideas that would be great. Thank you
Derrick Jones
Oct 3, 2018 08:06 AM
Maximus99
Sep 1, 2015 03:12 AM
Blagger
Apr 15, 2014 12:27 PM
joeba
Aug 2, 2011 08:58 PM
shk999
May 10, 2011 10:24 PM
