2008 UK Outlander ETV fuse blowing (code P0487)
Old May 27, 2018 | 06:35 AM
dave07973's Avatar
Default 2008 UK Outlander ETV fuse blowing (code P0487)
Hi everyone,
I need a little help trouble shooting the above fault.
On every other start I get the engine orange warning light illuminating. The code is P0487 Exhaust Gas Recirculation Throttle Control Circuit A/Open. I can clear the fault light with my OBDII scanner but after the second engine start the fault light returns.
I have found that the 15amp fuse in the engine fuse box (fuse position 8 ETV) also blows on every second start.
Can anyone point me in the right direction to resolve this issue.
Thanks
Old Feb 24, 2024 | 11:51 AM
JayVousden's Avatar
Hello there, I have the exact same problem on my "007 Outlander 2.0 DI-D. Did you resolve this problem. Please message me at jayvousden@msn.com
Old Mar 5, 2024 | 04:37 AM
ZAC21's Avatar
Default Similar issue
Hi everyone,
Thanks
I have the same code plus a few extra ones. I've checked my fuse and it's fine.
If you managed to sort it please let me know.
Thank you
Old Mar 6, 2024 | 07:04 PM
JayVousden's Avatar
Hello all, I had the same problem, except I had a P00488 code as well as the P00487. I have replaced both the EGR valve and the throttle body(AKA Exhaust Throttle Valve). I also cleaned all the wiring plugs.
I then replaced the ETV fuse. This cured the EML coming so far. I've driven it for a week, lots of starts. I still have the P00487 code coming up and the vehicle will not rev cleanly past 2500rpm under load. I'm thinking electric so I have it booked in at Mitsubishi for a diagnostic run. My vehicle is an Outlander Warrior DI-D 2007. I hope this helps. Replacing the two parts mentioned above isn't too difficult. Just remove the engine cover brackets this helps with space. A short T30 key also helps. While I had the parts out I changed the oil filter and oil as I'd run two doses of EGR cleaner through it.
Old Mar 8, 2024 | 08:58 AM
ZAC21's Avatar
Mines is exactly the same vehicle!! My codes are (brace yourself) P0487, P0488, P2141, P0234, P0606, P0573, P0671-P0674 (all glow plugs but light turns off when it should and car starts first time), P0504. I've had a new egr valve put on. I run Achoil AR6900-D Max with every fill up. I think it's something electrical that's messing up everything.
Let me know how you get on please.
Good luck
Ironman
Aug 15, 2023 08:29 AM
mahicks3322
Nov 3, 2021 01:14 AM
Christopher Pugh
Apr 1, 2012 10:10 AM
rmconard
Mar 21, 2012 08:40 PM
Britvalencia01
Aug 7, 2006 12:39 AM
