2009 outlander cold start issues
Old Dec 5, 2018 | 07:31 AM
newoutlanderfan's Avatar
Default 2009 outlander cold start issues
Hey all...
have a 2009 v6 outlander about 205,000KM on it.
Now that it's winter here it has trouble starting first thing in the morning. IIRC we tested the battery last winter and it seemed ok but I don't ever remember replaceing the battery in the past. So is it time to do so - 9 years? I'm assuming yes?
Any specific type of battery needed? I've never replaced a battery before at all.
Thanks!
Dave
Old Dec 5, 2018 | 09:05 AM
copyboy311's Avatar
If your battery is original and 9 years old, it's probably ready to give up the ghost. When you describe it as "having trouble starting in the morning," do you mean it cranks slower than usual and doesn't want to turn over, or does it crank fine but just doesn't want to start easily? If it's cranking slow, that's the battery.
You can take it to your shop of choice and they'll recommend the right battery for you. Expect to pay somewhere between $60-$100 US to get one installed.
Old Dec 5, 2018 | 09:34 AM
The cranking doesn't seem too bad. It start seems to just start hard - shaking, growling. We also notice that in the winter if the gas tank is a 1/4 or less it really struggles as well.
No issues ever in the warmer weather regardless of fuel level.
Old Dec 6, 2018 | 09:44 AM
copyboy311's Avatar
That sounds like something other than a battery problem. Fuel delivery issue? Ignition coils? What's the history of your spark plugs?
Old Dec 10, 2018 | 07:10 PM
So it was the battery. However I'm assuming all memory got wiped as we had to reset the radio presets.
We had it done at the dealer. So what happens with all the ecu updates i had over the years? Are they all gone? Since it was done at the dealer, do they update the ecu or pcm or whatever it is after installing a new battery? We had that battery for 8 years ago that's a lot of learning gone lol
Old Dec 11, 2018 | 07:29 AM
Claude_A's Avatar
System updates are permanent learning (transmission) are semi permanent and will survive at least 30 minutes with no power, only radio station die rapidly.
I changed my battery after 5 years and only lost the radio.
8 years is stretching on a OEM battery
stanko
Nov 19, 2018 03:39 AM
mysticrythms
Mar 19, 2014 08:17 PM
jms
Sep 30, 2012 02:23 AM
VPower
Jun 10, 2010 08:01 AM
nyc95gst
Dec 14, 2007 12:05 AM
