2011 Outlander: USB stick always starting on first song
Old Nov 20, 2014 | 09:13 AM
Karl Lang's Avatar
Default 2011 Outlander: USB stick always starting on first song
2011 Outlander
I like to use the USB stick input as I can load up a few hundred songs at a time.
The issue suddenly is that as soonas I turn off the car and then restart it the first song on the USB stick isselected not the last one played.
In other words, if I turned off thevehicle while playing song number 123 I would expect the next time I use the USB song number124 being played and not start all over again at number one.
I looked in the manual and can’tseem to find a solution to this.
Hope I am explaining the issue clearly.
Any help is appreciated.
Old Nov 20, 2014 | 01:26 PM
11SE2HEAR's Avatar
Go to this thread, read it over & give it a try.....
https://mitsubishiforum.com/forum/mi...em-stic-39963/
Old Nov 20, 2014 | 04:18 PM
Karl Lang's Avatar
11SE2HEAR
Thank you very much for the quick reply I will try that.
Old Nov 24, 2014 | 09:02 AM
Karl Lang's Avatar
Worked like a charm !!!!
Old Oct 1, 2020 | 01:51 AM
Avery Andrews's Avatar
Default For me (MY2020), it's usb 2 vs usb 3
I have spent a fair amount of time on this problem, and for my 2020 Outlander, none of the above solutions worked, but the answer so far seems to be that it remembers and resumes the last song on usb 2.0 drives, but not usb 3.0. Unfortunately, usb 2.0 ultrafits, which are nice because they don't stick out or require a cable, are a bit hard to find, but there are still some available on Amazon. I've had success with 32G EMC and Sandisk drives, also assorted smaller ones. No kudos to Mitsubishi for lackluster support of newer USB technology.
ChrisOut
Jul 19, 2018 12:12 AM
henriquenog
Oct 3, 2012 02:11 PM
mitsuNJ
Aug 4, 2011 11:51 AM
dragonlancer
Jul 12, 2007 02:24 PM
tidus10
Dec 2, 2006 02:38 AM
