2014 Sport Transfer Case
Old Jan 22, 2021 | 07:48 PM
no1tmorrow's Avatar
Default 2014 Sport Transfer Case
Got a 2014 Outlander Sport that manual shows I need to change transfer oil. Stupid question is that the rear end or is there a front one and a rear one since it is 4wd? (no laughing)
Thanks
Thom
Old Jan 22, 2021 | 11:36 PM
DibbyDibbyDJ's Avatar
There is a rear diff, but the transfer case is at the front. To drain the oil it is a 10mm hex key plug on the unit behind the engine sump. To refill is not easy the 17mm Plug is behind the right hand driveshaft and above it slightly. Not easy to get a spanner on, but i normally use a 17mm offset ring spanner. Oil capacity is only about 500ml, and you must trickle it in. If youtry to go too fast air bubbles will just pump it out again.
Old Jan 23, 2021 | 06:53 AM
kev994's Avatar
Open the fill one first. Otherwise if you can’t get it open and you’ve already drained it you’re in a bit of a pinch.
Old Jan 23, 2021 | 07:08 AM
no1tmorrow's Avatar
Thanks guys,
I purchased Mitsubishi SAE80 super hypoid gear oil. I think that is the stuff?
Plus had to google 17mm spanner. Never heard a wrench called that.
Old Jan 23, 2021 | 06:09 PM
Yes super hypoid is the one.
Trans atlantic language differences. LOL
92-3kgt
Apr 22, 2019 10:46 PM
JoJoSmoot20
Mar 27, 2019 12:42 AM
Magoo
Dec 18, 2017 09:30 PM
ikegwuru
15
Jan 25, 2015 04:04 PM
the copier guy
Jan 6, 2012 09:49 PM
