2016 Outlander MMCS to SDA Head Unit Swap
Old Oct 8, 2021 | 06:44 AM
  #61
samyui's Avatar
Originally Posted by Vipermla
I upgraded already, it was almost plug and play, I had to modify the USB cable so the Apple Carplay phone stays in the glove compartment, I can still use the original USB outlet on the centre console however it is considered USB by the head unit and if I put something there I lose the audio on the phone I use for Apple carplay. I still cant make the mic work, hoping you have better luck than I am.
i will just buy a DAB/DAB+ antenna with fakra connection to make it simple.
please tell me if you were able to make your mic work. Thanks.
Hi did you modify the existing USB cable in your vehicle for CarPlay or one that came with the SDA? I'm in the process of reading up on how to get the SDA in my 2016 5H.
Thanks in advance
Old Oct 8, 2021 | 09:26 AM
  #62
samyui's Avatar
Originally Posted by cf125
fantastic reply found the group and found a guy who did it and has post lots of info about it so thank you so much for the facebook group, cheers
Oooh could you send me a link to the post? I think I found the group.
Old Dec 27, 2021 | 07:59 PM
  #63
Vipermla's Avatar
Waiting for this cable to arrive. It has the same connectors but not really sure if compatible.
AU $42.96 | CABLE,USB,eclipse cross SDA 2 PORT HSL HIGH SPEED LINK, ECLIPSECROSS GK0W
https://a.aliexpress.com/_mtED4Oy
Thanks in advance
Old Dec 29, 2021 | 12:57 AM
  #64
Vipermla's Avatar
This is the original connector
This is what I am waiting for right now.
Old Jan 2, 2022 | 08:25 AM
  #65
babbancarter's Avatar
Exclamation No HFM?
Hey guys,
New member here from Australia. I was just installing the SDA unit in my 2014 ASX which had the MMCS in it. Needless to say, I needed help making the mic work. However, going through these forums and tons of wiring pinouts, I realised the wires I need are meant to be out of the HFM and quite conveniently, it turns out my asx has no HFM. Is that even possible? Considering the bluetooth hands free has been working fine but all I got is a 20 pin and an 18 pin connector. Thanks!
UPDATE: Sorry, I do infact have the HFM, turns out in the ASX it is actually hidden a bit lower behind the aircon controls so I couldnt see it earlier. All sorted now. I have a fully operational SDA unit. Yay!
Old Jan 14, 2022 | 11:56 PM
  #66
Vipermla's Avatar
I can confirm that these cables work, I used it with an iPhone 12 pro amd used Apple Car Play and it worked on both cables.
Old Feb 21, 2022 | 04:22 PM
  #67
mrjono's Avatar
Default I made a video!
Hey, I made a video of my journey doing this on an l200.
hope it helps, any questions fire away!
Old Feb 22, 2022 | 05:59 AM
  #68
daveg1966's Avatar
Default Great Video - one question
Mrjono,
What a great video, I'm just starting the swap from an MMCS to an SDA in a 2014 Outlander PHEV.
One question, what did you use to get the 3 pins out of the connector on the HFU so that you could reuse them. I've seen these connectors before where you use a tool to depress the latch on each pin so that you can pull the connector out but I've been unsuccessful so far.
Other than that, great help and many thanks for taking the time to post the video.
Cheers
Dave
Old Apr 23, 2022 | 10:48 PM
  #69
KelseyO's Avatar
Default Steering wheel tuner controls
I have just done this conversion. I have a problem that the my tuner steering wheel controls searches for channels, rather than going to the next programmed channel. Is anyone able to sort that out?
Old Jun 9, 2022 | 10:45 AM
  #70
holl595's Avatar
I recently completed the swap on a 2017MY outlander, although it had the hands free module the existing MMCS unit had the grey mic plug so I didn’t have to re-wire it.
I did however order the grey mic plug in preparation, if anyone needs one rather than using hot glue this is the correct plug.
https://a.aliexpress.com/_vnLxgq
The gps antenna (grey plug) can be made to fit without pulling it apart by simply removing the ridge on the top right of the plug.
I also used the following adaptor to plug the existing usb socket into the SDA. The pins needed moving round but that wasn’t hard.
https://a.aliexpress.com/_uWUf4W
if your ordering the adaptor then a DAB extension can be purchased from the same seller for much less than Amazon.
https://a.aliexpress.com/_vB92qq
Hopefully these links help anyone else wanting to move from the MMCS to SDA.
