2018 Outlander No Headlights
Old Oct 3, 2022 | 02:41 PM
jbrodeur76's Avatar
Default 2018 Outlander No Headlights
I searched the forum with no luck with this issue.
It's a 2018 and the headlights wont turn on. High beams work if you hold the lever...that its.
Fuse is fine. I read it could be a relay but cant locate where this is? Search to buy does not list headlight relay as an option but Im not a car guy
any suggestions would be fantastic.
Old Oct 12, 2022 | 08:05 PM
sean9721's Avatar
Do the low beam and high beam indicators light up on the dash? Any clicking from under the hood when turning on your lights?
Old Oct 22, 2022 | 03:52 AM
daem0n's Avatar
What light mode is turned on the lever? (off, auto, ...??)
Check light sensor (fuse, relay). One can also check settings in ETACS regarding conditions at which head lights turn on. (need special MUT3 tool).
A possible problem with ETACS. Start with disconnecting the battery, leave it for 30min, then connect and see if ETACS got any reset. If not, then ETACS need to be replaced unfortunately.
Old Feb 14, 2024 | 05:43 AM
Holmes1135's Avatar
Have you had any luck rectifying this issue? This is exactly what just happened to my wife. Low beams don’t work on both side, high beams work, but won’t click on, you have to hold the stalk.
Any idea what I’m looking at?
Scott Bauman
Feb 4, 2020 09:22 PM
klaviermann
Apr 17, 2008 09:55 PM
wb12859
1st Generation
Sep 14, 2007 05:06 PM
didineedthat
Oct 1, 2004 05:04 PM
boosty
Aug 12, 2004 02:41 AM
