accelerates when idle or in park
i have a mitsubishi outlander 2003. i don't know much about mechanics so i'm hoping someone could explain this problem to me in layman's terms. when the car is in park the engine sounds too high, the rpm gauge shows 1500. then it will drop down to about 800 rpm only to jump back up to 1500 rpm. it does this pretty consistently when in park.
what could be the problem??
RE: accelerates when idle or in park
It could be anything fuel/air related plus mechanical. It depends on particular design and control logic. I would suspect an uncontrolled air leak, so whenthe throttle is closed, some air still gets past it increasing the idle rpms. ECU cuts the fuel (as per algorithm's threshold)to decrease the rpms since it knows of the idle condition and/or closed throttle. Anything else you would figure from there. Try to analyse when/why/how this problem occured, maybe you will get a better idea of how to fix it.
Good luck troubleshooting.
CB12xlRiCh
07-11-2005 05:47 PM
