accelerates when idle or in park
Old Aug 20, 2008 | 07:46 PM
lrt's Avatar
lrt
Default accelerates when idle or in park
i have a mitsubishi outlander 2003. i don't know much about mechanics so i'm hoping someone could explain this problem to me in layman's terms. when the car is in park the engine sounds too high, the rpm gauge shows 1500. then it will drop down to about 800 rpm only to jump back up to 1500 rpm. it does this pretty consistently when in park.
what could be the problem??
Old Aug 21, 2008 | 09:01 AM
HandyPal's Avatar
Default RE: accelerates when idle or in park
It could be anything fuel/air related plus mechanical. It depends on particular design and control logic. I would suspect an uncontrolled air leak, so whenthe throttle is closed, some air still gets past it increasing the idle rpms. ECU cuts the fuel (as per algorithm's threshold)to decrease the rpms since it knows of the idle condition and/or closed throttle. Anything else you would figure from there. Try to analyse when/why/how this problem occured, maybe you will get a better idea of how to fix it.
Good luck troubleshooting.
Old Aug 21, 2008 | 02:10 PM
azjake's Avatar
Another thing to check is if this only happens when your A/C is on. When the A/C compressor kicks on it can raise your idle rpms.
Old Aug 21, 2008 | 02:28 PM
Sergy's Avatar
I support azjake in opinion about A/C.
Old Aug 22, 2008 | 09:20 AM
chenarm's Avatar
I'm not sure I fully understand what you are saying. does the RPM remain at 1500 constantly when in Park or does it jump up and down between 800 and 1500 RPM?
waits43105
14
Oct 29, 2011 02:30 AM
johnaljay
Aug 3, 2011 11:51 PM
CB12xlRiCh
Jul 11, 2005 05:47 PM
EliteM6
May 15, 2005 03:04 AM
Dans Talon
Feb 9, 2005 10:13 AM
