Advice Needed on Having Water Pump, Timing Belt, etc. Changed
Old Jul 11, 2016 | 01:07 AM
SERPENTOR's Avatar
Originally Posted by archersofloaf
Thanks for your response Serpentor. I did check rockauto.com, and was only able to find the following brands: GMB, ACDelco, Airtex, Gates, ITM, Pronto, Beck/Arnley, and Cardone. I've only been able to find the BTK pump at the dealer, or as remanufactured from an auto parts store (I've been told not to get a remanufactured pump though).
Thanks again.
My advice is to go with the brand that gives you the best warranty.
Old Jul 13, 2016 | 10:31 PM
archersofloaf's Avatar
Thanks Serpentor; I'll check out the warranty information for each pump.
Old Jul 14, 2016 | 03:01 AM
SERPENTOR's Avatar
Thumbs up
Your welcome glad I could help.
Old Aug 13, 2016 | 05:33 PM
Hi Guys,
Sorry for reviving an old thread, but I have a follow-up question. Originally, I was told by a service rep at a dealer that my water pump is leaking, and he showed me that my water pump had a little coolant on it. I called a different dealer to get a quote on replacing the pump, and the service rep told me that he's never seen one go bad before 200k miles. I know it'll be different for everyone, but that made me think that maybe I should look into it a little more before just deciding to have the pump replaced.
Looking at the pump that's on my car now, I saw that it had maybe about 2 tablespoons worth of coolant caked onto it, which I removed with a screwdriver. I don't know if this is how it normally is when it dries, but the dried coolant was sort of pliable. I don't know if there's more of this caked coolant maybe blocking the weep hole, but I drove the car for 10 miles and didn't notice any moisture or drops of coolant. When driving the car everything sounds fine, but with the hood open, I can hear a consistent low sort of chirp (or squeaky hinge) sound every half a second or so; I'm not sure if this sound is normal though. Do you guys have any thoughts/recommendations?
Thanks again.
Old Aug 13, 2016 | 07:50 PM
Sic_Lucky's Avatar
I can;t directly answer your question but I can give you my experience with 2 different outlanders. My first outlander was a 2003 (not the same engine as your 06) but I did the timing belt and waterpump. The oem belt was unitta which is a japanese company which is now owned by gates. I didn't look at the brand of the waterpump but I replaced it with an airtex pump. I drove the car for almost 2 years before selling it and there wasn't any issues with the belt, pump or tensioners.
My 2nd outlander was an 07 (not the same engine as your 06) and at ~148k the belt looked good (unitta) and the waterpump looked great (hitachi). Replaced them with gates belt and gmb waterpump. Let's see how they hold up but the gmb pump looked solid and identical to the oem hitachi.
Old Aug 14, 2016 | 10:46 PM
Thanks for sharing your experience Sic_Lucky. It sounds like it could be a little early for my water pump to go (or maybe I just got unlucky and it is failing prematurely). Maybe I'll see if I can take it to another mechanic to get a second opinion before just ordering a new pump and having it changed. Thanks again!
adamsstreetauto
Feb 23, 2018 05:43 PM
raycam2kx
Feb 21, 2008 11:08 PM
raycam2kx
14
Oct 6, 2007 08:31 PM
raycam2kx
Aug 16, 2007 08:33 PM
bcolins
Jul 5, 2007 07:35 PM
