Aftermarket Head Unit with GPS - wiring
![Unhappy](https://mitsubishiforum.com/forum/images/icons/icon9.gif)
Out of curiosity how many people with an aftermarket head unit connected their speed wire (usually pink wire) ?
Supposedly you can leave it unconnected, but with it connected, your able to determine your location much better on the GPS.
Currently I dont have mine connected, but I cant find the wire to connect it to.
help?
help?
![Frown](https://mitsubishiforum.com/forum/images/smilies/frown.gif)
wire 31 on third connector (C16/C17) on this wiki (white with blue line)
Second Generation Outlander Stereo Wiring - Mitsubishi Wiki
is this for a 2009 outlander?? i see it says something about a 2010.. ill check when i can, thanks!
The connector is the same for all years.
Fuse for 2010 is inside the new system but the wire going to the system are the sames.
Also the speed sensor is used to kill the video on the MMCS when moving so it is present and most probably at that position as I don't see Mitsubishi having multiple harness.
alright thanks so much!
![Big Grin](https://mitsubishiforum.com/forum/images/smilies/biggrin.gif)
alright, so i tried wiring it up and im not sure if that was the right wire because once i hooked it up, my gps started freaking out so i just removed it. Ill try and see if i can figure it out.. i think maybe the wiring is different because its an 09 outlander. hmm..
I also checked here --> http://jdmfsm.info/Auto/Japan/Mitsub...9/index_M1.htm and it's the same for 2009
![](http://img705.imageshack.us/img705/6531/speedsensorj.jpg)
DriverX5
08-27-2012 02:45 PM
mchang40
04-25-2010 10:23 AM
