Aftermarket Head Unit with GPS - wiring
Old Apr 27, 2012 | 02:03 PM
xOutlanderFiendx's Avatar
Unhappy Aftermarket Head Unit with GPS - wiring
Out of curiosity how many people with an aftermarket head unit connected their speed wire (usually pink wire) ?
Supposedly you can leave it unconnected, but with it connected, your able to determine your location much better on the GPS.
Currently I dont have mine connected, but I cant find the wire to connect it to.
help?
Old Apr 27, 2012 | 03:56 PM
Claude_A's Avatar
wire 31 on third connector (C16/C17) on this wiki (white with blue line)
Second Generation Outlander Stereo Wiring - Mitsubishi Wiki
Old Apr 27, 2012 | 04:00 PM
is this for a 2009 outlander?? i see it says something about a 2010.. ill check when i can, thanks!
Old Apr 27, 2012 | 04:47 PM
Claude_A's Avatar
The connector is the same for all years.
Fuse for 2010 is inside the new system but the wire going to the system are the sames.
Also the speed sensor is used to kill the video on the MMCS when moving so it is present and most probably at that position as I don't see Mitsubishi having multiple harness.
Old Apr 27, 2012 | 05:26 PM
alright thanks so much!
Old May 3, 2012 | 02:21 PM
alright, so i tried wiring it up and im not sure if that was the right wire because once i hooked it up, my gps started freaking out so i just removed it. Ill try and see if i can figure it out.. i think maybe the wiring is different because its an 09 outlander. hmm..
Old May 4, 2012 | 09:27 AM
Claude_A's Avatar
This is what the wiring diagram show for a 2007. This signal is constant 12volt and it say I am moving but not how fast If that is what your GPS need then we need to look at the signal out of the transmission.
I also checked here --> http://jdmfsm.info/Auto/Japan/Mitsub...9/index_M1.htm and it's the same for 2009
DriverX5
Aug 27, 2012 02:45 PM
DavidJ1988
Oct 28, 2011 06:51 PM
ajoesmith
Jul 17, 2011 05:33 PM
mchang40
Apr 25, 2010 10:23 AM
WarChicken
Apr 1, 2006 04:21 PM
