Back-up Sensor on 2007 XLS
Old Oct 20, 2012 | 07:55 PM
skipperx's Avatar
Default Back-up Sensor on 2007 XLS
Mine is one of those that beeps and shows the distance on a little readout at the top of the rear window. It started to malfunction recently. The distance values are all wrong and blinking a lot. Can someone please shed some light. Is there a battery I am supposed to replace or calibrate the thing or what?
Thank you.
Old Oct 20, 2012 | 08:44 PM
Vadimus's Avatar
Hardly.
Check the connection, especially power.
Most likely it is a unreliable connectivity issue.
Old Oct 25, 2012 | 12:04 PM
skipperx's Avatar
Thank you, Vadimus for getting back. I have checked the lower sensors in the bumper and there is no sign of lose connections or wires. I do not know how to get to the ones higher up. Do I remove the inside panels in the cabin to get to them?
Please allow me to ask some dumb questions. I don't know how it is wired because I did not install the system. But I know it was came installed from the dealer when new. So I hope it give you a good idea of how it is installed.
It does look like a bad or diminishing power source like you said. It is fading gradually more now. Now there is only a little red dot on the rear window display and no sound. Occasionally it would blink and beep erratically. If there is no battery in the sensor system where do I check for main power coming into it? I mean is there some main control unit for it and all the sensors and the display are connector to it? If so where is it usually mounted?
Thank you.
batman47
Dec 4, 2011 04:21 PM
Lukin
Jul 26, 2011 07:42 AM
Cougster
Aug 21, 2008 08:30 AM
Silvertooth
Mar 16, 2007 04:42 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
