Best Motor Oil for my Outlander?
Old Aug 27, 2006 | 05:54 PM
expositor's Avatar
Default RE: Best Motor Oil for my Outlander?
i would think that a 500 to 1000 mile break-in period should be sufficient for that to occur, but again....i was told by my dealer's parts mgr that synthetic was ok, so, as i mentioned previously, after about 1200 miles when i did my first oil-change i went with 10w-30 synthetic. when i take the car in for a semi-annual check-up, i'll ask again with more direct specificity.
Old Aug 27, 2006 | 07:25 PM
dirtwagon's Avatar
As long as the dealer says it's okay, you're good to go....as long as the parts manager doesn't quit or transfer...lol. That's good to know though, I likely will not run full synthetic in my car though...not yet anyways.
Old Aug 30, 2006 | 11:24 PM
deftones's Avatar
I went with Castrol Turbomax Guardian 15W-40 non synthetic. Here's a thing that's got me a little peeved. I bought a 4 quart jug, the dealer called me up later and said they needed a 'little' more so on my way down to the dealership I picked up a 1 quart container. Later the car was ready and he said they used most of the 5th quart! He gave me what was left, which was basically nothing. So they used a full 5 quarts for my first oil change, doesn't that seem like a lot? Should I tell them to remove a 1/2 quart to prevent damage?
Also, how in the hell can you tell the oil level on the dipstick? That has got to be the worse dipstick I've seen in my life, there are only two levels etched on the stick but they are only about 1 inch apart from eachother and the oil level has always been way, way above the top level from the first day I bought the car [&o]
Old Aug 31, 2006 | 02:08 AM
dirtwagon's Avatar
i thought we had 4.5 qt capacity, I'd have to double check it to be sure. If the dealer put almost 5 qts, then it's their fault if something breaks due to that- but check your owners manual, it will tell you what the capacity is.
Old Aug 31, 2006 | 11:58 PM
expositor's Avatar
i thought 4.5 qts as well. if you don't see bubbles on the dip-stick, you should be ok; and it is difficult to check the level. i've found at ttimes that it shows a little higher on one side than the other; go figure....i'd try to pin the dealership on overfilling your crankcase so you don't have a warranty issue in the future.
Old Sep 1, 2006 | 02:51 AM
deftones's Avatar
That's what I'm going to do tomorrow and next time I'm only bring 4 quarts. Dissapointing that a Mitsubishi dealership would knowingly overfill one of there own cars!
racinshorty1
May 16, 2007 05:20 PM
reggieccrgto
Jan 23, 2007 09:38 PM
BlackMurcielago
Jan 20, 2007 05:44 AM
naka
Oct 12, 2005 10:11 PM
Topspin800
Nov 16, 2003 12:32 AM
