brake pad rattle..
Old Aug 27, 2015 | 05:23 PM
07xlsguy's Avatar
Default brake pad rattle..
Hello. Just put new Wagner ThermoQuiet ceramics on the front wheels of my 07 XLS Outlander. Also put new hardware clips in place. now they rattle like a son of a bitch. Does anyone have a good way to stop this rattling? Thanks
Old Aug 28, 2015 | 09:16 AM
ccernst's Avatar
did you put the shims on too with caliper grease? I'm on my 2nd round with those pads and they are pretty quiet.
Old Aug 28, 2015 | 05:20 PM
07xlsguy's Avatar
Yes. I greased the pad clips front and back before installing into the caliper.. I have had a set of these on previously with no rattle however as well..thinking of taking them back out and expanding clip and pushing in more tightly..?
Old Aug 31, 2015 | 07:49 AM
07xlsguy's Avatar
Installed[1] new rattle clip on both front outboard pads{top of pad} and rattle is somewhat less.. dumb question but, is more than one rattle clip required on front outboard pad{bottom of pad}? Also is the outboard pad the correct one for the clips --can the inboard pad rattle as well?
thanks again ccernst!
Old Sep 1, 2015 | 10:09 AM
ccernst's Avatar
to be honest....I didn't replace my clips on the Outlander. I remember my clips were still firm...so I ran with what worked. I honestly just replaced the pads and that was it. I do remember there being two clips, one for top and one for bottom. knock on wood, this is one issue I've yet to battle myself.
Old Sep 1, 2015 | 10:21 AM
gggplaya's Avatar
Try taking off the grease, i never use grease on mine. I either replace with new hardware slides or use a wire wheel on a drill to clean the existing slides. Never had an issue with rattle or noise when using decent brake pads.
Almost all the aftermarket pads i use have glued backings, so i don't think shims are needed, or are even applicable for the outlander.
My guess is the OEM doesn't use grease because you do actually need some friction to prevent the pad from moving and bouncing back and forth.
racerx55
1st Generation
Oct 5, 2007 07:41 AM
Akmikek
Nov 6, 2006 01:35 PM
Torque
Jul 31, 2006 02:59 PM
RakMej
Jan 27, 2006 02:35 AM
FireDoc
Oct 14, 2005 01:05 AM
