Can anyone help? Dash lit up after boost
Old May 15, 2016 | 07:50 PM
rob3307's Avatar
Default Can anyone help? Dash lit up after boost
sad to say something happened when i got a boost last weekend... no idea what happened but after i had a full system meltdown on my dash, lost my speedo, odometer not working either, and it cycles through the warnings of
check abs
check traction control
check engine
tire pressure warning
the 4x4 is flashing "4wd" then "lock" alternating one for the other
only thing on the dash working properly is the tach...
checked all the fuses but none seem blown... not sure whats going on. I can monitor my speed and everything fine on a wireless obd unit I have connected to a tablet
I did get a u0100 fault code
Old May 18, 2016 | 10:41 PM
gggplaya's Avatar
You blew something, i would check all fuses and relays. Most likely, whoever boosted you also connected the cables backwards and reversed polarity, which typically blows fuses, but can also backfeed into a controller and fry it.
I would drive it to the dealer, and have them hook it up to their computer, it should show which controller is offline. You might need to replace it, or fix the relay or fuse.
Old May 19, 2016 | 04:16 AM
Lancerguy2013's Avatar
gggplaya...exactly right...happened to my sisters truck one time after a boost...she took it to the Dealer and they replaced a controller and a software reflash or some such thing.....it was a pretty easy fix...but cost her some dough...best of luck.
Old Jul 14, 2016 | 12:15 PM
rob3307's Avatar
ya.... i blew the abs controller it seems which they want over 3 grand for... anyone know where to find used parts cheap online? i cant find anywhere under $1200
need oem part number 4670A346 for a 08 outlander v6
rob3307
May 14, 2016 10:07 PM
JRK5892
Jul 1, 2013 12:54 PM
lane6939
Jun 28, 2012 01:34 AM
91ricerocket
Jun 15, 2008 05:39 AM
jcasaccio
Mar 23, 2006 12:33 PM
