CVT Oil UK
Old May 7, 2018 | 10:55 AM
Nameless's Avatar
Default CVT Oil UK
Hi, I have a 2008 outlander. I didn’t get a manual with it and am having problems finding the right type of CVT oil. I have read that I should use diaqueen. But have not been able to find anywhere that sells it in the UK, Other than a seller on eBay which says meets the manufacturer specifications Mitsubishi Dia-Queen
SSTF-1
MZ320065
. A generic manual I found online says to use DiaQueen CVTF-J1.
I can find a CVTF-J1 for Japanese/Korean Cars.
Anyone in the UK had any luck with a DIY replacement?
Thanks guys.
Old May 7, 2018 | 11:10 AM
Nameless's Avatar
i'm new to CVT. But from what i've read, its been over filled and is the wrong colour.
I take it, being this colour means time to change?
Old May 7, 2018 | 11:25 AM
AWCAWD's Avatar
Do not use any substitute. You will regret it.
Use only what is required for your vehicle. If your CVT fluid is green use DiaQueen CVTF-J1. If your current fluid is almost transparent use DiaQueen CVTF-J4. Generally darkened color is the sign that is due for the change.
Old May 7, 2018 | 11:35 AM
Nameless's Avatar
I Would, but not even the car parts companies sell it here in the UK.
Old May 7, 2018 | 11:47 AM
AWCAWD's Avatar
I suggest that you should ask directly what Mitsubishi UK headquarter recommends as a substitute.
Old May 7, 2018 | 06:02 PM
Lancerguy2013's Avatar
DO NOT USE any other fluid...no matter how "compatible" it's advertised to be.
This is the correct and only fluid that goes in that Transmission...full stop.
Amazon Amazon
Outie_NZ
Jan 25, 2025 05:55 AM
Tango4N
May 3, 2018 09:07 PM
mich42
Apr 23, 2018 04:08 AM
Mitsuwoo
Mar 19, 2018 02:42 AM
Truwarrior22
Mar 6, 2018 01:49 PM
