CVT transmission issue
Old Jun 22, 2023 | 09:33 PM
scepticpsych's Avatar
Default CVT transmission issue
Hi all,
I have a 2012 Outlander with the 2.4 engine and CVT transmission. It has a noise and hesitation occasionally in D when you expect it to shift gears. We took it to a mechanic and they found that the transmission cooler and coolant had been mixing because the transmission cooler had corroded. I can replace that, but the bigger problem is that he said the transmission was pretty much 'done' and needed to be replaced which will be 7k+. I am not sure he even took it for a drive, I think this was his assessment after pulling the transmission drain plug and finding black gunk coming out.
I took it for a drive recently and it actually drives fine for the most part and it shifts perfectly fine when you put it in manual mode.
Just wanted to get a second opinion - do these transmission usually completely fail? Would it be worth just changing the transmission fluid and see if that rectifies the issue?
There is coolant in the transmission fluid and transmission fluid in the coolant (milky brown). Also wanting to see if there's anything else serviceable in the transmission that I could replace before writing off the car completely.
Old Jun 22, 2023 | 10:27 PM
Truwarrior22's Avatar
Originally Posted by scepticpsych
Hi all,
This seems to be a common problem. It appears after a certain year, these coolers no longer exist (at least my 2016 doesn’t appear to have one, just the one in front of the condenser). Sadly, I believe the last instance I saw the transmission needed to be replaced.
Old Jun 23, 2023 | 06:47 AM
I can get a cooler off ebay so that shouldn't be a problem.
I should also note there is no issue with slippage or hesitation (or noise) when I drive in 'manual' mode. Does that mean it's mechanically okay and could be a solenoid or something?
Old Jun 23, 2023 | 07:33 PM
DibbyDibbyDJ's Avatar
If the trans oil has been contaminated by water, the the trans is trashed. Changing the oil may help in th short term, but the seals inside will start to degrade and it will not last long
Outie_NZ
Jan 25, 2025 05:55 AM
mcmars
Apr 27, 2023 09:43 AM
Lanceolotl
Apr 26, 2023 05:45 AM
nyjetshead
Feb 19, 2022 07:10 PM
acfyffe
Sep 21, 2015 01:51 PM
