Does fuel Matter
Old Feb 28, 2008 | 03:50 PM
antlip's Avatar
Default RE: Does fuel Matter
Some gas stations have prem at 93oct.
Old Mar 1, 2008 | 09:09 AM
David_Barrera's Avatar
I just fill up the thank with Plus 91 Oct, the manual said any gas just it has to be 90 or higher
great, just to come from a 95 oct with the Evo..
here are just like 10 cents the difference from one to another
Old Mar 3, 2008 | 03:41 PM
klas's Avatar
I had TSX prior to Outlander and it explicitelly stated "Premium only" in the dashboard and near gas tank.
I didn't look in the Outlander'smanual, but I read before and heard from a dealer that it runs on a regular. If your manual says using 90 or higher that basically means Premium gas which I don't think is true...
Old Mar 18, 2008 | 01:48 PM
jnetter's Avatar
I just bought a 2008 XLS and the manual states 87 or higher, so regular is just fine... any other grade is just a waste of money.
Old Mar 19, 2008 | 07:37 PM
bnilguy's Avatar
I think it's more important to pic a brand name gas (one that does more than the minimum detergent standard) and that gets alot of traffic (fresh gas)
North American folks check out www.toptiergas.com
Old Mar 19, 2008 | 10:26 PM
DeadPoolinc8's Avatar
What brand do you use? last few times i used Gulf and Lukoil. i might start to use Shell sinces its at least in the list
Old Mar 20, 2008 | 12:24 AM
OTO27's Avatar
I've always used shell, forgot why I started using it, I probably read somewere it was one of the few companies that used good qualitty additives. I'm kind of happy it was in that list, I knew shell was agood company since I've had 2 cars both make it past 150,000 miles on shell, but this is conqrete evidence I guess.
Old Mar 20, 2008 | 01:26 AM
rcpax's Avatar
BTW, who maintains that list? Strange that BP is not on the list.
Old Mar 20, 2008 | 06:12 AM
chenarm's Avatar
There aren't that many suppliers, maybe 3-4 in a given area, even the no-name gas station get there gas from a major supplier, I've never heard of a no-name refinery. Certainly the argument of using a high traffic gas station is a good idea. If for what ever reason the gas is being contaminated, at least the contamination is diluted and you get less of it per tank.
As far as additives, Shell had to change or remove their additive a few years ago, after realizing that it cause some major issue with some fuel injection system.I would rather not have any additives at all since MMC says to not use any and if it does cause problem, you 'ed be stuck paying for the bill or suing the gas company (this is what happened in the case of Shell).
Old Mar 21, 2008 | 12:02 PM
2g0s0r1's Avatar
In short:
Regular is the "minimum" recommended octane for the outlander.
You can usehigher grades with no detrimental effects, and possibly no beneficial effects either.
Read this article and you will be WELL INFORMED for cars sold in the USA: http://www.api.org/aboutoilgas/gasol...ine-octane.cfm
nyc95gst
Mar 22, 2008 04:54 PM
Germankat
Mar 19, 2008 05:28 PM
nisama
Feb 22, 2008 07:25 PM
agallardo
Feb 22, 2007 03:46 AM
phusion
Dec 23, 2005 10:36 PM
