Driver and Passenger Side/Rear-View Power Mirrors Not Moving Correctly
Old Feb 3, 2019 | 08:28 AM
SERPENTOR's Avatar
Default Driver and Passenger Side/Rear-View Power Mirrors Not Moving Correctly
Driver and Passenger Side/Rear-View Power Mirrors Not Moving Correctly, only adjust right to left but not up and down from control switch. Who can fix this type of issue only the dealer? Can a Firestone, Pepboys, or Meineke fix it as well? How much should this cost so that I don't get ripped off? It's for a 2008 Mitsubishi Outlander XLS V6 Automatic 4WD.
Old Feb 3, 2019 | 11:13 AM
AWCAWD's Avatar
Have you tried the continuity check I suggested in post #4 in your earlier thread here?
Old Feb 3, 2019 | 07:29 PM
SERPENTOR's Avatar
I am not that mechanically inclined to perform those steps, I did however check the fuse and make sure the mirrors are not folded.
Old Feb 3, 2019 | 09:57 PM
AWCAWD's Avatar
The up-down direction of your switch is not working properly. Take it to a reliable car electrician (with the file I supplied). If you are lucky it is just a contact problem. In the worst case scenario you need a new four-way switch.
Old Feb 3, 2019 | 11:09 PM
SERPENTOR's Avatar
Thank you how much do you think this should costs ball park figure? I just don't wanna be ripped off?
Old Feb 4, 2019 | 12:05 PM
AWCAWD's Avatar
If you go to a junk yard only few bucks and can pick up a 4WD/2WD control switch as well what you are also looking for. If you go to ebay it can vary from $10 to $79
Considering the age of your car I would not invest a lot in new parts or labor. I would go with the cheapest possible option.
SERPENTOR
May 23, 2023 09:51 PM
SERPENTOR
Jun 6, 2018 05:03 PM
mengxiao88
Feb 2, 2016 04:43 PM
bishigt_18
Nov 1, 2008 07:24 PM
BrianB
Apr 11, 2007 09:41 AM
