Old Dec 5, 2008 | 03:24 AM
  #561
Otaku's Avatar
Default RE: DVD in motion patch for NR261UM
ORIGINAL: Zox
Hi Otaku!
Could you explain, which way to put another language in your text.csv file? I wish to make a Serbian language pack for EM version. May I write the text in the same sheet, but in the next column?
Zox
Hi Zox..
Sorry : I should have mentioned that..
Yes, please the translation in the next column.
atb.
O.
Old Dec 5, 2008 | 03:25 AM
  #562
Otaku's Avatar
ORIGINAL: Rachev
For Otaku.
Yes in treeview 3 lines have appeared. But they do not open. The file opened from EMR, UM, EM.
All is identical.
It seems to me, you have software package which is not present at me.
Thanks.
Hrmm.
Wierd : I'll investigate this tomorrow.
atb.
O.
Old Dec 5, 2008 | 08:48 AM
  #563
NickNack's Avatar
Hi Otaku,
Is it also possible to enable the DVD patch with this program, or is this still a draft version? The reason why I am asking this because I was not able to save the file.
Thanks
Old Dec 5, 2008 | 09:13 AM
  #564
Otaku's Avatar
ORIGINAL: NickNack
Hi Otaku,
Thanks
Yes : thats a draft version.
The full version is complete, bar the testing of the images produced..
Which should happen over the next week..
atb.
O.
Old Dec 5, 2008 | 11:45 AM
  #565
WickedWhite6's Avatar
Otaku, do you know how I can fix mine? Or is there a way to figure it out? Or am I just screwed and have to buy a new navi?
Old Dec 5, 2008 | 02:23 PM
  #566
brian360's Avatar
ORIGINAL: WickedWhite6
How old is your car? If under warranty (1st year I think) then take it to the dealer.
Otherwise can you give some more info as to the nature of the problem? Does it still think you're in NY? Is the date/time set correctly? When you hit INFO and touch location info, does it see any GPS satellites? The reason I ask the last three is that should confirm if your GPS receiver is working. Does the radio, music server, Sirius, etc still work? Hold SET+INFO to get to the service menu, and look around the CAN Communications confirmations menus. I think there's also a Gyro test in there somewhere.
Old Dec 6, 2008 | 11:48 AM
  #567
NickNack's Avatar
To Otaku,
Thanks for your reply,
I have 2 questions and hope you can help me. This week I updated my MMCS with version H and a new MAP upgrade, do you have a DVD in motion patch for version H. I want to keep version H and do not want to go back to version E.
I was also wondering, does anybody know if it is possible to perform a MAP upgrade without the dongle on a MMCS system?
Thanks again for answers and help!
regards,
Old Dec 6, 2008 | 02:02 PM
  #568
brian360's Avatar
Insert your map upgrade DVD into a PC is there a file called "loading.kwi" in there? If so, upload it for us... Even better if you post a full dvd image, and better yet if you pull your hard drive and image the whole thing.
Old Dec 6, 2008 | 05:54 PM
  #569
Zox's Avatar
Zox
Hi Otaku,
Another question about your text.csv file, it seems to fit for US version, but will be useful for European version to? I noticed in text some words, which is not present in my (EM) version. (eg.Time zone, Pacific, Mountain, Central, Eastern... etc. )
I`m trying to translate for 2 languages, Hungarian and Serbian..
Zox.
PS. did You read my post #76 in EM tread?
https://mitsubishiforum.com/m_224329...8/key_/tm.htm#
Old Dec 6, 2008 | 07:16 PM
  #570
My car still has temp tags. Everytime i turn my car off and back on the clock resets to 4 oclock. The music server works. And it says im in ny or nj. It shows the gps senseo is working and gives a long and latitutde
