Old May 29, 2008 | 11:14 PM
  #61
Outie08's Avatar
Default RE: DVD in motion patch for NR261UM
Re-download and Re-burned another one,triedit again, same different , no action after checking cd.
Theiso file after I extracted is MMCS-261UM.ISO, size 24,828KB,created on to a blank CD-R using nero, 2 files on CD.
Am I missing anything here ?
Old May 30, 2008 | 12:03 AM
  #62
jsrd's Avatar
I used a CD-RW and there was no problem. Some message of error when you unrar the file? The size of your file ISO is exactly identical to which I obtained, and the “update†worked perfect. You can try with a CD-RW, although the format of the CD would not have to be problem. . .
Old May 30, 2008 | 12:16 AM
  #63
robh's Avatar
i redownloaded the .rar file and unziped it burned to disc a 5th time sill nothing
just says checking disc then nothing as if there is no disc in the drive
Old May 30, 2008 | 12:46 AM
  #64
jsrd's Avatar
robh, I repeated all the process of patch at this moment:
1. I Downloaded file .rar
2. Unrar file. I obtain 2 archives: MMCS-261UM.iso and readme.txt
3. Burn image MMCS-261UM.iso to CD-RW
4. In MMCS, I insert dics and start "Check Disc" screen
5. Few seconds later, show screen "Detecte a new program-Start loading" and two options: YES or NO
and everything worked well, so you must be having a problem with your burned software, maybe. On CD, you must have the following files and sizes:
alldata.kwi = 4 KB
loading.kwi = 24,464 KB
Old May 30, 2008 | 12:52 AM
  #65
robh's Avatar
that is correct those are the 2 files and sizes i have but after it says checking disc nothing happens it just goes to the radio and does nothing
Old May 30, 2008 | 01:02 AM
  #66
robh's Avatar
do i have to take the drive out and unlock it first ? then update it or what
Old May 30, 2008 | 01:49 AM
  #67
biscuit's Avatar
I didn't have to take my drive out.
Old May 30, 2008 | 02:04 AM
  #68
jsrd's Avatar
robh, the procedure that created Otaku and rcostin eliminates to pull out the HDD; we needed more ideas to obtain your update; Otaku, brian360, rcostin?
Old May 30, 2008 | 02:20 AM
  #69
POMPOUS_JACKASS's Avatar
EDITED: Sorry, it is v1.09
I have also tried this, and am experiencing the same issue as robh. My MMCS version is also: bld-nr-261um v1.09
Old May 30, 2008 | 02:26 AM
  #70
rcostin's Avatar
ORIGINAL: Otaku
You want to start a thread for feature requests ?
I was thinking to a poll
ORIGINAL: POMPOUS_JACKASS
bld-nr-261um v1.0 or bld-nr-261um v1.09 ?
