EGR fault - code P0487,P0488
Old May 21, 2020 | 04:31 AM
  #31
Simon Parke's Avatar
Originally Posted by iceno9
Its a long time since i looked at this problem.....but have you cleaned out the throttle body where the EGR valve lets exhaust gases back in? If that valve is somehow stuck in the open position thereby letting too much exhaust gas back into the inlet manifold, you will loose power. From what i remember, its easy to remove and clean with a solvent and should only take an hour or so.
Hi there did you ever get your 487 fault code sorted? And can you advise how you managed it? Cheers
Old May 25, 2020 | 07:20 AM
  #32
iceno9's Avatar
I got it so it rarely came up. But the vehicle has long since been sold now.
Old Jul 4, 2024 | 06:51 AM
  #33
JayVousden's Avatar
Exclamation More questions
Hello all, I have a 2007 Outlander MK 2 DI-D. I also keep getting the P0487 code. So far I have replaced the EGR valve, the throttle body attached to it, had the turbo replaced with a refurbished one which has a brand new turbo controller on it. I still get the code coming up. Also when I first drove the vehicle after having the refurbished turbo installed the vehicle seemed to run fine. Then it started stuttering again and often won't accelerate cleanly past 2500rpm. This doesn't happen all the time. The message talks about a throttle position control circuit. I have also heard that the throttle on this vehicle is Fly-By-Wire and that there is no physical connection between the pedal and the throttle. Are there throttle position sensors that need to be cleaned?
Jay
Old Jul 5, 2024 | 08:35 AM
  #34
iceno9's Avatar
Jay
Its a long time ago now that i had that vehicle....but i recall the butterfly valve was in the throttle body and motor controlled (fly by wire as you said).....you could try carburettor cleaner to make sure it not gunged up....
redlancer
Sep 5, 2015 01:56 PM
2007OutlanderElegance
Jul 15, 2014 09:18 PM
iceno9
Jun 17, 2013 10:43 AM
3000gt123
Sep 22, 2006 04:45 PM
3000gtyeah
Aug 17, 2005 08:22 PM
