EGR Outlander 2011 2.2 DI
Old Apr 21, 2024 | 11:08 AM
sinamics's Avatar
Default EGR Outlander 2011 2.2 DI
Hi
I have been strugling with the P2413 EGR code for a while, and today i removed the EGR valve to have a closer look.
It was full of carbon as expected, but the electric DC motor seems to be defect as well. Meassuring 180 Ohms, and tapping on the motor makes the Ohm value dance.
The EGR stem and valve seems fine, so i only need a new DC motor.
I can only find replacement motor for (Pajero Triton Shogun), but the motor looks exactly the same.
Does anyone know if i can use this motor?
The original part number is: 1582A260 - K5T74091
It also seems like the new EGR replacement partnummer is 1582A554
Car info:
VIN: JMBXJCW1WBZ000293
Model: OUTLANDER (II) 4WD
Engine: 4N14
Year: 2011
Old May 7, 2024 | 03:28 AM
Welna84's Avatar
Hello , struggling with exact issue with exact part number. I did replaced motor from 2018 Outlander and engine works smooth but engine light comes out. I took the motor off and bottom of the motor looks different to the original (spring fitted at the bottom). I found that L200/Tritton egr motor looks same to ours and I will give it a go 1582A483.
Old May 7, 2024 | 10:31 AM
sinamics's Avatar
I also ordered the L200/Tritton motor, will let you know how it goes when i get the part. Fingers crossed.
xmor
Mar 6, 2023 08:56 PM
leojbourne
Oct 16, 2022 04:25 PM
Daniel-K
Jan 30, 2018 03:23 PM
Kristenl2784
Jun 1, 2017 08:38 AM
Dvidcervenka
Jul 30, 2009 09:28 PM
