ETACS options customization
Old Apr 13, 2014 | 08:02 PM
  #1061
whis's Avatar
Thanks. I go there and register as member
Old Apr 13, 2014 | 10:04 PM
  #1062
beyjer's Avatar
Thank you!!
Old Apr 20, 2014 | 02:03 PM
  #1063
denis234's Avatar
I put a new eatcs ECU on Mitsubishi outlander 2007 and now it does not work climate can not close the door and write me a system error what to do
Old Apr 22, 2014 | 05:11 AM
  #1064
brickwalls's Avatar
Antone has sucess applying changes using ETACS with a MY14 ASX/Outlander Sport/RVR ?
Old Apr 23, 2014 | 09:30 AM
  #1065
Vadimus's Avatar
If you're local I can help.
Old Apr 23, 2014 | 04:04 PM
  #1066
mortod's Avatar
Default ETACS & Bluetooth
Can Lexia3 be used to enable the OEM Bluetooth module (I think the setting is within the etacs, ie enable HFM), rather than having to take to a dealer to use Mut3?
Thanks.
Old Apr 23, 2014 | 04:07 PM
  #1067
Vadimus's Avatar
Yes, for non FUSE/Link versions of BT (mostly pre-2010), part# ends with 009.
New generation of BT module (025 onward) does not use CAN bus so it does not need to be activated.
Old Apr 24, 2014 | 08:13 AM
  #1068
mortod's Avatar
That's great. Even better, I took a look behind my MMCS and it seems I already have the BT module installed (& the mic), so hopefully it is just a matter of activating it.
I'm surprised that Mitsubishi would have installed it and just not activated it if not purchased. Is there any lookup tool to see what accessories my car was supplied with when new? It's possible that the module is faulty I suppose, though it would be nice to know if it was ever meant to work, or was just disabled.
Also, found a video of yours on Youtube Vadimus, showing the MMCS responding to touch (ie moving the map around without having to use the joystick). Is that something that came with later software or hardware? ie would a software upgrade to MMCS enable that feature (mine is 2007 EU version)?
Old Apr 30, 2014 | 06:36 PM
  #1069
Snare_TS's Avatar
Anyone have default settings list for Lancer GT 2014 using ETACs decoder 2.9.9.7h? Service engine light popped up but reverting back all my settings to originals doesn't seem to clear it. Might be missing which settings would affect this system.
Old May 2, 2014 | 10:34 AM
  #1070
Vadimus's Avatar
I will check if I have one later.
