ETACS options customization
#1113
Hi,
Do you mean you want to read the error code and clear the fault? The diagbox should be able to do that unless the fault is permanent.
#1114
Errors reads me set the car as a Peugeot but I can not remove this error.
Maybe even try to set for Citroen.
I changed radio and was an error but it is not a permanent problem because previously removed the Mitsubishi on it and it was OK. When you turn on the ignition and leave the panel with LED error later such problems.
Soon again I will again change the radio to the new, and probably will again this error. I would like to know if someone was able to remove it, and under what settings - Mitsubishi ASX 1.6 5MT.
#1115
I don't know how you can clear the error once you get it other than at the dealer.. I have heard people not having success clearing air bag errors sometimes...
Make sure you didn't leave anything disconnected and next time you do work on your radio disconnect the battery until the work is complete to avoid any errors.
#1116
On RVR/ASX/Outlander Sport it is enough to turn ignition once while having radio faceplate disconnected - and non-disappearing airbag light will stay until erased.
On Outlander however, it is enough to reconnect faceplate and airbag light is gone.
#1119
#1120
dear Vadimus,
all I can say thank you so so so much.
you just made my day bro and I appreciate you for showing me this.
I have two question for you
1- what do I need to remove it? ig.laptop with windows 7 or xp, which program should I use diagbox or what and which device Lexia-3 there are many versions should I buy.
2- is it easy to do or should I back up something before I start playing with it?
best regards,
