ETACS options customization
Can anybody comfirm that this will work on a 2012 GT?
I would get one just to have the doors lock when the fob is out of range and unlock when back in range- Saw this feature on a Toyota Venza and would like it on my new GT. Also the auto lock at xx mph and unlock at P (park), windows up,asunfoof closed with fob, ect.
Thanks
Thanks
I am getting the following error when trying to activate Diagbox 6.02 "error during installation of lexia. you have to reactivate to restart the installation" I entered the serials correctly. What can i do to fix this?
EDIT: NVM i found the youtube video....followed it...worked like a charm
Im having an issue installing PP2000. Im geiing the error "Installation Impossible: The version in the portable is more up to date than version of the cd rom confirm to end"
I installed and activated both diagbox and lexia successfully. what can i do to install it?
Thanks for they reply...i was searching for awhile to find out why. Now im gonna play with it on my lancer and see what i can do
Ok i upgraded Diagbox to 6.22
I open peugeot and click on 4007...i have a 09 lancer....Im not sure if im connected to my etacs correctly. Can someone post a step by step on how to communicate with the etacs with diagbox. I want to be sure im doing this correctly.
thanks
thanks
ok here is what ive learned.
I got the cable to comuinicate with the etacs...i think. it auto reconizes the vin #. i can get it work using peugeot 4007 or 4008...i tried 407 and 408 and its not reconized. when scanning...it shows ecu not reconized for most of what is scanning. any option i select to edit and validate, it shows a graph and i cannot change any value.
ive spent about an hour exploring different options. What am i doing wrong?
09 lancer GTS
09 lancer GTS
Well i figured out how to access programming the parameters. I have to go into repair. im not sure what i did but when i went into repair - configuration - manual configuration - vehicle configuration - programming by default...the car switched on and off.
this is what i found out by doing that.
DRL is now disabled
fog lights are now independant
abs service light is on
airbag service light is now in
i went into manual configuration and cannot get rid of the service lights
what can i do?
well now ive discovered more issues.
4wd lock service light is now flashing...i dont have 4wd
the door unlock when touching the handle does not work anymore.
the horn beep when activating and deactivating alarm does not work anymore.
ive tried to repair the issues via diagbox with no luck. ive tried using peugeot 4007 and 4008 with no luck in repairing. Is there another vehicle profile i can try to use to fix it?
My next option is to remove diagbox and install lexia and pp2000.
my car is a 09 lancer gts
