ETACS options customization
Old Nov 10, 2012 | 08:39 AM
  #531
allezzov's Avatar
TrailBrake and Vadimus - Thank you for your response !
I should change my two Outies in a couple of days...very much appreciated !
Old Nov 10, 2012 | 01:55 PM
  #532
Gen-8's Avatar
Vadimus how you going with that program you were doing ? I am eager to change stuff in etacs with the lexis device but am too scared to do anything after reading everyone's failures lol.. Eager to see if the JDM spec can be changed lol
Old Nov 10, 2012 | 02:32 PM
  #533
galant2003's Avatar
Originally Posted by Vadimus
You need to press double gear button to save.
First double-click the item you want to change.
It appears a screen where you can select the correct value.
Press the ok-button and leave the screen.
Press the double gear button to save to etacs.
Press the back-button to leave the selected menu.
Pay attention: every customer-settings like e.g. light-sensor will go back to the manufacturing value after reprogramming a value in "programming by default". You have to change again with MMCS or Diagbox.
Press the home-button in the top of the program to leave the session.
Good luck...
Old Nov 11, 2012 | 05:52 PM
  #534
TrailBrake's Avatar
Well, I tried to disable the TPMS today using the steps as described, and got the following unexpected message:
Enter access code supplied by technical assistance.****
I even tried uninstalling and going back to Diagbox 6.19. Still no dice
Any idea what I did wrong?
Old Nov 11, 2012 | 06:43 PM
  #535
Vadimus's Avatar
You need TLCD fix.
Old Nov 12, 2012 | 06:44 AM
  #536
TrailBrake's Avatar
You need TLCD fix.
Thanks. I will install the fix and give it a try later today.
Old Nov 12, 2012 | 06:54 AM
  #537
allezzov's Avatar
TrailBrake,
I will be attempting to execute my changes tomorrow. In the event I run into the same situation as you, where do I obtain "TLCD fix " ?
Old Nov 12, 2012 | 07:14 AM
  #538
TrailBrake's Avatar
Originally Posted by allezzov
TrailBrake,
I found it using Google.
If you can't find a link to TLCD fix, you can probably find a Diagbox update that includes the fix (updates for v6.20 and v6.24 appear to have it).
Old Nov 12, 2012 | 10:20 AM
  #539
galant2003's Avatar
Search in google for:
tlcdfix.rar
Second link...
or use a Diagbox from Scary. All versions up 6.20 have the fix included.
Old Nov 12, 2012 | 06:47 PM
  #540
TrailBrake's Avatar
After using Scary's 6.01 to 6.24 update w/ TLCD fix, I am happy to report my TPMS is now disabled
A 10 minute test drive after disabling the under inflation detection had me grinning ear to ear.
A huge thank you to Vadimus for assisting in getting this newbie up to speed.
