ETACS options customization
Old Dec 7, 2012 | 03:26 PM
  #591
boogunoogun's Avatar
soo when/where can I get this custom software? Awesome work vadimus
Old Dec 7, 2012 | 03:36 PM
  #592
Vadimus's Avatar
Well, I'm only a assistant in a development of ETACS decoder.
I'll let you know when and how much
Old Dec 7, 2012 | 11:41 PM
  #593
sgtr275's Avatar
Hi everyone!
I am trying to program my 2010 lancer using diagbox 6.19. I select C-Crosser and diagbox is able to read my VIN and most of the ECUs. However, I do not find the ETACS menu anywhere. It seems like others are successful with similar cars and the same software version so I wonder if anyone else has run into this issue and could point out what I could be doing wrong.
Old Dec 8, 2012 | 08:13 AM
  #594
Burtonrider10022's Avatar
Has anyone here made a little "cheat sheet" that they could post up? There is a wealth of information in this thread but it's getting quite long and hard to find some things.
Also, I believe Vadimus said he was working on a program for this? Is it still in development or could someone possibly point me in the direction of finding it?
Thanks,
-James
Old Dec 9, 2012 | 12:58 AM
  #595
Thanks,
-James
see above. still in development. He will let us know when and how much eventually. I hope it is soon!
Old Dec 9, 2012 | 03:05 PM
  #596
Vadimus's Avatar
Found a pic of dashboard with both headlight autoleveling and stock CANbus parking sensors installed.
Old Dec 9, 2012 | 05:30 PM
  #597
allezzov's Avatar
Default Daytime Running Light Question
My wife's 2010 Outlander has DRLs. From what I see it is the low beam at a reduced voltage.
My 2012 does not have DRLs. I hooked up my Lexia device and in DiagBox found the appropriate settings for the daytime lights and tried each setting. My lights do not activate in the DRL mode. Am I missing a voltage regulator board or is the wiring different between years? Thanks.
Old Dec 9, 2012 | 06:41 PM
  #598
Vadimus's Avatar
Just in case - did you put transmission in D, parking brake disengaged?
Anyway, DRL relay could be missing. Not a big deal, they are pretty standard.
Note that reduced output DRLs require special PWM relay, identifiable by a metal radiator on its top, while independent DRLs use ordinary one.
Compare two relay boxes - if you '12 has an empty socket where '10 has that fancy relay - that's it.
Old Dec 9, 2012 | 07:42 PM
  #599
allezzov's Avatar
Yes Vadimus, I engaged into Drive with Parking brake disengaged. My wife's 2010 has a relay in position marked "O" that takes up the entire slot with a large heat sink on the top. My 2012 , in the corresponding position has a small black relay which basically is 1/3 the size and is centered in the relay slot. I will swap the relays and see what results in the near future.
All of us on the Forum really appreciate your input. Thanks !!!
Old Dec 9, 2012 | 08:21 PM
  #600
otromen02's Avatar
Default Headlamp Leveling
Originally Posted by jsrd
I bought each part separately, I do not know if there is something like a kit. These accessories were bought in 2008, in dealer at the Long Beach, CA.
8634A022 - ECU levelling
8651A047 - Sensor, RR
8651A095 - Sensor, FR
8303A016 - Sub harness, RR
8303A015 - Sub harness, FR
Hi - I got all the above parts and plug it in the sockets available in the car, but seems like it's not working. Anyone can help to share where I can enable this in the ETACS and how do i verify whether it's working or not? Thanks
