experience with Slime tire sealant
Old Aug 26, 2009 | 04:43 PM
azjake's Avatar
Default experience with Slime tire sealant
I am considering purchasing a kit that includes Slime tire sealant and an air pump that runs off the 12 volt plug. Has anybody had any experience using Slime to fix a flat in an emergency?
If Slime does work, it would be quicker, easier, and less messy than actually changing the flat and putting on the space saver spare.
Also, I can't use any fix a flat products that come in aerosol cans because of the heat here in Phoenix (can may explode when left in hot car), but Slime is a liquid in a plastic bottle and not affected by the heat.
Old Aug 27, 2009 | 10:51 AM
Manybrews's Avatar
never ever use tire sealant.
Old Aug 27, 2009 | 03:29 PM
tcp's Avatar
tcp
Default Prepare to buy a new TPMS sensor
If you ever do use slime, be prepared to buy a new TPMS sensor for that wheel. The slime will render it inoperative. Let the tire store know you've slimed as well, they don't like the surprise of slime all over themselves and will disparage your lineage.
Old Aug 27, 2009 | 05:01 PM
azjake's Avatar
I've read articles on tire sealants where they say you should warn the tire tech that you've used the product so they don't get sprayed with chemicals when busting down the tire.
Slime claims the product is water soluble and can be washed out of the TPMS sensor with water so it can be re-used, but since they don't back it up with a guarantee I realize you are taking the risk of sensor damage when using their product.
Old Sep 1, 2009 | 03:03 PM
Manybrews's Avatar
thats what a spare is for.
never use tire sealant.
Old Sep 2, 2009 | 01:54 PM
azjake's Avatar
After thinking about it some more I've decided not to get the Slime kit.
Laxstar785
Aug 22, 2006 12:30 PM
X3M
May 5, 2006 01:59 AM
MrBadExample
Mar 29, 2005 05:07 PM
daladiezman1627
Aug 21, 2004 07:33 PM
Sirandi
Feb 20, 2004 02:37 AM
