fast key retrofit help
Old Dec 14, 2021 | 03:15 PM
07xlsguy's Avatar
Default fast key retrofit help
Hello. My 07 Outlander Xls Has the fast key system system. The Ignition lock switch failed and there are no replacements available in the US, Canada or Japan( Part # 6370a920). Does anyone know if it's possible to retrofit the fast pass Ignition switch with a with a standard Ignition lock switch, possibly from the ES or LS model ?
Old Dec 15, 2021 | 06:23 AM
07xlsguy's Avatar
Anyone?
Old Dec 15, 2021 | 02:36 PM
SERPENTOR's Avatar
Try these guys I buy from them and usually they are cheaper than my local Mitsu Dealer
https://www.mitsubishipartswarehouse...IFJlc3VsdHM%3D
Old Dec 18, 2021 | 12:31 PM
lobuc's Avatar
The wire connection looks similar between fast key and standard. I don't know anything about the fast key deal but if it was mine I would definitely try a cheap new or used standard switch not lock cylinder. Should only take about 10 minutes and $10 to find out.
07xlsguy
Dec 9, 2021 06:13 AM
jrmdir
15
Oct 17, 2020 12:13 AM
Philip Scott
Feb 11, 2020 05:08 PM
monterosport57
Aug 10, 2011 09:30 PM
blamesociety
Dec 24, 2005 07:50 PM
