Going to look at '08 XLS 2wd tomorrow.
Old 12-31-2007, 10:07 PM
armymen's Avatar
Default RE: Going to look at '08 XLS 2wd tomorrow.
if you have the deluxe package you have the eletric one, but you probably dont have it.
i have the 08 version.
You have 2 thing to control your see.
One is like a pump to put your seet up and down.
and the other one is to put your seat forward and back.
I was messt at the begining :P me too
Old 12-31-2007, 10:39 PM
Emil's Avatar
I don't have the power seats. I do understand how to move the seat forward/backward, but the seatback is the problem. I can not adjust the seat while sitting. I have to physically get out of the car to adjust the seat.
Old 12-31-2007, 11:21 PM
Maybe try leaning forward to remove all weight off of the seatback. If you are applying weight to the seat back, it will cause a bind in the ratcheting mechanism and will not allow for adjustment. If after removing your weight, it still will not adjust, then it's apparent that it's a safety issueto prevent adjustments while driving... or in this case,even while seated in the vehicle.
Old 12-31-2007, 11:23 PM
Emil's Avatar
Well, that's interesting. Every car I've had with manual seats you could adjust the seatback without having to get out.
Old 12-31-2007, 11:28 PM
Interesting indeed, but how often do you need to adjust the seatback? I understand sharing a vehicle with some short petite female sucks, re-adjust mirrors, seat, pedals, radio presets, and temperature control.
Old 12-31-2007, 11:36 PM
armymen's Avatar
do you have 2 thing too control your seat ?
i dont know your version have that.
Old 01-01-2008, 06:15 AM
Sergy's Avatar
One quick question. My drivers seat doesn't adjust when I am sitting in it. I have to stand outside the car to adjust the seatback. I am thinking something is broken?
Do you have electro-driven seat?
How are you weight?
My weight is about 80kg, mechanical seat. Up-down seat lifting is starting with some crisp... but from second-third pull all ok.
All others seat adjustments work fine.
Hmmm... I had this situation twice. But I'm lazy )) and didn't get out from my car. I rised up holding by steering wheel.When understanded how it works: first pull(push) need to make with some force.
Old 01-01-2008, 04:15 PM
Emil's Avatar
Nevermind! I was using the wrong lever.[:@]
Old 01-01-2008, 04:57 PM
bnilguy's Avatar
The dealersonly seemorder XLSs that are either 'base' or loaded...they had to go about 300 miles to findme an apparently rare XLS FWD with Sun/Sound/Luxury and no Nav
Old 01-02-2008, 10:38 AM
Kwanger's Avatar
ORIGINAL: Emil
I was going to say, never had a problem in mine!
cybergoogle
01-31-2010 12:13 AM
mahicks3322
12-03-2008 07:14 PM
GotBoost
03-23-2007 12:17 PM
chelsel
11-27-2006 04:57 PM
Quick Reply: Going to look at '08 XLS 2wd tomorrow.
