Has anybody experienced jerking movement when shifting from reverse to drive?
Old May 6, 2010 | 05:57 AM
mchang40's Avatar
That's a very good point. And you might be correct if this situation happened every morning.
However, this only happened once on that cold morning. The temperature was in the 40 to 50 range and the car was parked outside that night. Ever since then, the temperature has been above 60 in the morning and I never had that jerking issue again, even if I mash halfway on the accelerator after switching from reverse to in Drive.
Old May 6, 2010 | 07:08 AM
mchang40's Avatar
And one more thing, on that cold morning, it didn't just jerk one time, It jerked 4 or 5 times in a row. Back and forth rapidly.
On warm mornings it jerks slightly when I step on the gas after switching gears from reverse to Drive.
Old May 6, 2010 | 10:30 AM
nesser's Avatar
Sorry mchang40, I didn't clue in that the ES had the CVT in it.
I don't have any experience driving the CVT, just an outlander that has a standard geared transmission.
Cheers,
Chris
Old May 6, 2010 | 10:50 AM
nesser's Avatar
No need to idle that long it's just a waste of gas.
Less than a minute is more than enough. The aluminum block on the engine dissipates most of the heat while idling even though the computer elevates the RPMs. What you are looking at in the gauge is the temperature of the coolant in the engine - not the transmission.
Other threads talk about warming up the vehicle in the winter and how long it takes at idle. Give this thread a read to learn more - more threads can be found by searching for "heater".
https://mitsubishiforum.com/forum/sh...ghlight=heater
Cheers,
Chris
Originally Posted by mchang40
It takes 5 to 10 minutes for the temperature on the onboard computer temperature guage to go from Cold to warm (in the middle). Are you saying I should wait that long?
Old May 7, 2010 | 06:04 AM
mchang40's Avatar
OK Thanks!
donovan53
May 27, 2013 05:48 AM
shawark
Jun 2, 2008 07:46 AM
n0c7
Apr 14, 2008 06:15 AM
Nubiebubie_GSX
Mar 2, 2007 08:03 PM
mitsubishi_newbie
Nov 9, 2005 07:23 PM
