HID Conversion DONE! (Pics and info)
Old Oct 8, 2010 | 02:15 PM
  #111
ryandlor's Avatar
Originally Posted by armymen
so i order
9005/HB3 12V 65W Crystal White
9006/HB4 12V 55W Crystal White
50$ CAN to ship to canada
for the park light W5W i already have LED bulb so everything will look nice with everything
thanks
Whoa...
Isn't 65 W a bit to much for our reg halogens? I think you will need a wriing Harness for those bulbs...
Old Oct 8, 2010 | 02:29 PM
  #112
armymen's Avatar
Originally Posted by ryandlor
Whoa...
haha maybe lol
what is that wiring harness ????
how much are the normal one ?
Old Oct 15, 2010 | 08:05 PM
  #113
Lander2010's Avatar
Default any difference on 2010 Outlander?
Hi there - very good info guys, was just wondering if I need to do anything different on 2010 Outlander before HID installation.
Looked at the harness kits Alim was talking about but that it seems that this specific harness only goes up to 2009 model. So there must be something different in 2010 model, wish I knew what .
Mick
Old Oct 16, 2010 | 07:10 AM
  #114
RAMON-'s Avatar
haha maybe lol
I am not sure what gauge wire is running from the light relay to the light socket on the Outlander.
If the wire gauge isn't heavy enough it will melt the insulation on the wire if you use a higher watt bulb.
I believe armymen referring to a harness means using heavier gauge wiring harness OR just heavier gauge wiring.
Old Oct 18, 2010 | 12:08 AM
  #115
serego's Avatar
So why people take the time to convert to HID light ? If they can achieve the same with that bulb ?
yes its kind of confusing
imho, HIDs do provide more light. Once you have 'crystal white' on, just compare with HIDs on other cars and you will see the difference. Also, consider bulbs lifetime - it used to be really bad and before I switched to HIDs I had to replace 'crystal white' twice a year...
Old Oct 18, 2010 | 12:13 AM
  #116
serego's Avatar
nice comparison in details - HIDs do provide more light per watt:
http://www.candlepowerforums.com/vb/...ad.php?t=73986
Old Oct 21, 2010 | 07:31 PM
  #117
ShortyRider's Avatar
I jus bought a HID kid and harness and installed it, with a solder capacitor.
Everything work great. However, when I first turn on the light, the driver side light flickers for maybe 1-2 secs. Is this a problem, or will the flicker go away after some time of using it. It doesn't flicker after you turn it off and on. It only flickers when you first turn on. Once is warm up, no problem. And on the first turn on of the light, it takes 5 sec for the HID to produce full intensity. Is this a normal thing too?
Old Nov 23, 2010 | 09:16 AM
  #118
MM3Canuck's Avatar
Quote me if im wrong on this one, but I experienced this on my friends Golf. Same issue until he up sized the cap.
The flickering you are getting will destroy your ballast. If it is a digital one, it might not harm it, but it might once in a while go in to safe mode (shut off, and restart). I believe the flickering in YOUR case is caused by a wrong sized capacitor. It might not be big enough. When HIDs first turn on, they draw a huge amount of power to warm up the bulbs. (place your ears close to the ballast, you will hear it humming for 2-5 seconds, until the bulbs are 100% warmed up...this is normal with after market kits) This power draw; if the capacitor is too small, will result in flickering.
Old Jan 28, 2011 | 02:58 PM
  #119
dklr's Avatar
Default dekodan
Do you have the part number of the hid kit you used in your low beam conversion on the Mitz. Outlander. If not could you let me know where you aquired it from. I would greatly appreciate it. Thanks.
Old Jan 31, 2011 | 03:49 PM
  #120
dsmgod's Avatar
Default hids wont work
hey I have installed my HID's like you did in the pictures and when i turn my lights on the flicker oncer then they go out can any one help me out these are brand new HID so i don't think it is the ballasts or any thing else could it be i need to upgrade my fuses please help.
