Hood dents at Hinge Location (2007 XLS)
Old Jun 27, 2008 | 12:40 PM
  #31
lmart121's Avatar
Default RE: Hood dents at Hinge Location (2007 XLS)
I finally took some images. It ishard totell unless you get the sun right in the photo. You can see it is in the same place as the rest. In addition I show a profile photo that shows how misaligned the hood is compared to the fender.As most of you who have this issue know, it looks much worse in person.
Has anyone had any luck with the dealership so far?
Old Jun 27, 2008 | 07:05 PM
  #32
armymen's Avatar
yeah im interest i still have 400 km before my next oil change, so if somebody ask to the dealer yet will be nice to know
I got super good service there, ( they say all the problem i got with my car so far is in my head so )
im not suprise they say i did those hole again !!!! [:@]
This is realy my last mistu car heyhey
Old Jun 30, 2008 | 11:16 AM
  #33
puddy's Avatar
I used to spray parts for the Lotus car company in Norfolk UK. I would say this to me looks like the skin and underframe were not stamped properly and should have been rejected in the factory before being fitted.
Paint used on jap cars is very brittle and a mark/dent like that would have paint damage if done after the car was painted. Becareful in having a paint less fix dent repair unless the dealer agrees first that if the paint does split that they will replace the bonnet. Filling sanding and re-spraying on an already damaged bonnet/hood is a no no on a car less then 6 months old.
You could have an independent inspection done to see if the damged bonnet has been repaired by testing the paint thickness or checks to see if filler has be used by the factory
why do dealers say we dont know of any problems in our range when in fact they do but keep quiet I have a on going problem with Mitsubshi UK with the dim radio display even though I have told them Mitsubishi sweden have a fix
puddy
Old Jul 16, 2008 | 01:18 PM
  #34
armymen's Avatar
Hi just arrive from the dealer, oil change, and i ask if they know about that dent, and they say something have press in the hood to make those,
ya they blame it on me.
they say they never herd about that problem
ya right ,,,,
Old Jul 18, 2008 | 12:09 AM
  #35
killerbuzz65's Avatar
Well now I know I'm not crazy. I noticed small dents only on the driver side hood, near the crease. I would post pics but my 2007 Lab Cab is a bit dirty (damned birds too). I will check with the dealer about the issue when I see them next week. (My rear wiper fluid jets don't work- but that another forum)
kb65
Old Jul 24, 2008 | 08:55 PM
  #36
armymen's Avatar
what dealer tell you
me they always put blame on me
service is [:'(]
Old Aug 19, 2008 | 11:10 PM
  #37
armymen's Avatar
hi,
can i have all the picture send to my email with all your permition
i need :
Your serial of your car
Model and years and colors,
and a picture of it,
( send to my personnal Email, «patthe @ gmail . com» with no space
im sick of my car, i just found some RUST !!! on my 2008 car, and i got diamon coat and the chip for no rust !!!, and i got that dent, and my tire is crack, and i fix my sub 2 time for rattle, they fix my gaz open device 2 time, ect ect ect ...
im sick of it !!!!
thanks [:@]
Old Aug 20, 2008 | 05:00 PM
  #38
rtrackr99's Avatar
Do you think the hood ripples are related to the openning and closing of the hood?
The hood seems kind ofheavy and the hood rod prop-open point is onlyto one side, near the driver's sideof the hood.
I've seen larger Import car hoods that have the prop-up point near the front and closer to the middle instead ofon thedriver's side like the Outlander. This seems to be a morebalanced location to hold the hood open.
I wonder if this is too much stress on the driver's side hinge mounting area thus causing the ripples.
It seems like my ripples didn't appear until I started to open the hood for maintenance and oil changes.
Old Aug 22, 2008 | 07:04 AM
  #39
rancho66's Avatar
I have a dent in the same place on my 2007 LS too...I agree that it is be caused by the hood being propped in that location when open. I tried to take some pics, but cannot get the ding to show. It is not a big dent, but noticable when in right light and angle.
Old Aug 22, 2008 | 09:29 AM
  #40
chenarm's Avatar
I wonder if it's because the hinge on that side of the hood doesn't have enough travel, i.e. when the hood is closed the hinge is pushed beyond its travel and is constantly applying pressure to lift the hood?
