How to Change the Battery?
Old Dec 28, 2011 | 05:05 PM
cooljw's Avatar
Default How to Change the Battery?
I have a 2008 Outlander SE and need to change the battery and I would prefer to do it myself.
However, the air intake passes over the battery and I can't figure out how to remove it in order to take the battery out. The air intake attaches to the air filter box and I can't figure out how it detaches from the box. Has anyone done it?
Old Dec 28, 2011 | 10:41 PM
ccernst's Avatar
two plastic screws holds the air intake tube to the grille...then unsnap your filter from the box...that removes that. Not the most fun thing to put back together, but that's what I did when I replaced mine.
Old Dec 29, 2011 | 12:16 AM
cooljw's Avatar
I got the two plastic screws out no problem. But I can't seem to get the air intake to unsnap from the filter box. How hard did you pull/wiggle? I'm afraid to break something.
Old Dec 29, 2011 | 07:19 AM
SERPENTOR's Avatar
Lets go bros help a fellow gearhead out. We all learned the hard way now share the knowledge at least for the Holidays
Old Dec 29, 2011 | 10:12 AM
ruski's Avatar
The air filter box has two metal clips. Unfasten them and the airbox will separate.
Old Dec 29, 2011 | 02:54 PM
SERPENTOR's Avatar
Thx man
Old Dec 30, 2011 | 07:14 PM
cooljw's Avatar
OK I figured it out. Actually there is no need to remove the air filter - you should also not as far as I can tell because this would further require removing the half of the air filter box which is connected to the air intake (and there is also an additional bolt you would have to remove as well as wiring attached to this half of the air filter box).
Instead I used a screwdriver to pry the air intake out of the air filter box (it's attached by a clip - but you can sort of bend the plastic with a screwdriver).
Thanks for the replies all.
Old Jan 14, 2013 | 01:18 PM
cooljw's Avatar
Someone put a nice video of how to change the battery up on the Internet: Battery Replacement: 2007-2010 Mitsubishi Outlander - 2010 Mitsubishi Outlander ES 2.4L 4 Cyl.
Old Apr 14, 2019 | 09:41 PM
lovemymitsu's Avatar
Had the same issue. The following video posted on YOUCANIC showed it how to disconnect the air intake and replace the battery.
https://www.youcanic.com/video/2008-...ry-replacement
waid302
May 8, 2021 01:14 AM
davidonbowen
Nov 2, 2012 02:17 AM
mlhj45
Apr 3, 2012 11:49 AM
drebin891
Feb 6, 2010 08:47 PM
eross
Aug 13, 2005 04:32 PM
