How to connect aftermarket Nav unit to Rear Roof DVD
Old Oct 8, 2011 | 10:33 PM
ajoesmith's Avatar
Default How to connect aftermarket Nav unit to Rear Roof DVD
I have had an aftermarket sat nav now for a while and have it all hooked up, everything is great.
The only thing that i cant figure out though is how to play a dvd on the sat nav in the front and get it to display on the roof mounted dvd player.
I can do it as the front unit has a dvd out but that means i have to drag a cable from the front to the back RCA in sockets.
Is there another way of doing this? I thought that all the connections/wires for connecting the genuine MMCS to rear dvd was already in the car?
can anyone help?
Old Oct 9, 2011 | 10:54 PM
greatcat's Avatar
I think I have done something similar here :https://mitsubishiforum.com/forum/mi...navi-hu-39598/
can anyone help?
Old Oct 10, 2011 | 03:58 AM
ajoesmith's Avatar
thanks for that
so which wire is the video and which is the ground? purple or blue?
ALso i will be using an rca cable just like you, i have cut it and there are 2 wires inside, inner core wire with white coating then another wire with outside black coating.
AM i correct in that the inner wire is for video and other wire is for ground?
Old Oct 10, 2011 | 12:18 PM
greatcat's Avatar
Smile
thanks for that
Honestly, I can't remember exactly. But what I did was simply test them before you tape these up. it will not hurt at all.
For the RCA, you are right.
Share us some pictures when you done
Old Oct 11, 2011 | 02:36 AM
ajoesmith's Avatar
Ok looks like i dont have the same connector as you do greatcat.
My outie didnt come with sat nav but it had a free connector taped to other cables when i removed my old stereo. However that free connector doesnt look like yours. Mine is much shorter and I cant figure out which one is for video if any at all
Old Oct 11, 2011 | 11:33 AM
greatcat's Avatar
I know exactly what you're talking about because we all have the same outie.
I don't think I did, so Let me make it clear here:
I guess what you want to do is, cut the wires from the other side of the harness that are connecting to the light blue and purple and tap your RCA connector to them.
That way you don't need the connector I used. All that connector does was making the wiring easier.
I hope I made it easier for you. Let me know if you have any other questions.
Attached Thumbnails How to connect aftermarket Nav unit to Rear Roof DVD-img_0193.jpg
Old Oct 21, 2011 | 07:48 AM
ajoesmith's Avatar
Greatcat
this didnt work.
Are you sure this is for video OUT? or video in?
I need video OUT
I want to
Old Oct 21, 2011 | 11:31 AM
greatcat's Avatar
Greatcat
this didnt work.
I need video OUT
I want to
Sorry, my bad. These were for vedio-in from the central arm rest.
I don't have a top mounted DVD, so can't test. However, if everything is hooked, the video should be able to be on both the DVD and HU together.
search for that diagram, it should help.
I will also post it here once I found it.
Deon
May 11, 2015 01:45 AM
mehr_ak
Oct 13, 2013 01:34 PM
ajoesmith
Jul 12, 2011 06:41 PM
rayp35
Dec 10, 2007 08:14 AM
oldpapa1949
Nov 16, 2007 12:00 PM
