How to unlock MMCS
Old Jun 17, 2009 | 03:52 AM
  #111
dernayka's Avatar
Default new mmcs
do you have closer photos bizzlex ?
Old Jun 18, 2009 | 08:49 AM
  #112
oper82's Avatar
i believe u can see a closer picture there http://www.flickr.com/photos/crgphot...7618222632435/
no idea though what system that new mmcs is.
Old Jun 18, 2009 | 08:49 PM
  #113
bizzlex's Avatar
thats the 1 !!
thanks for the post Oper8r
thats the new one with no HD
Old Jun 19, 2009 | 08:14 AM
  #114
dernayka's Avatar
Thanks for the link. it looks like there is a mic or a light sensor on the down right side.. wondering why the Japanese makes of it a secret project. Can't download mp3, can't load other maps, no online support, no offline support as well...
Old Jun 22, 2009 | 04:36 AM
  #115
greeneagle's Avatar
Default can't view picture links
Sorry about the dum question, but can anybody tell me what I am doing wrong? I click on the img links in from the How to unlock message but I can't see the pic's. A new window opens with all the forum sections to which I can not select anything.
Old Jun 22, 2009 | 06:27 AM
  #116
jsrd's Avatar
You aren't doing anything wrong, simply many pics and links disappeared/broken when the forum updated to a new software version...
Old Jul 6, 2009 | 04:53 PM
  #117
nikos D's Avatar
Originally Posted by rcostin
I can send you a clone image from my disk (Outlander '07 Europe). The operation needs an extra ATA notebook disk, not SATA (just to be sure you don't screw yours with incompatible data).
Disconnect the battery for about 30 minutes, restore that new disk from clone, put it inside MMCS, reconnect battery, restart the unit and see if everything is ok. If you are satisfied, overwrite the original disk (is a little bit more special that an ordinary notebook disk - automotive grade - so in real life you should use that one) and use it. If don't, put the original hard drive back as it was before.
ATTENTION
After placing a disk inside MMCS, it will be locked with the same pass. To use it further, you need to unlock it.
PS
To unlock the DVD there are 2 ways:
1. Rewrite firmware in DVD player itself (not MMCS but the DVD)
2. Trick the MMCS' operating system to fool the player that the disk is the correct region (kind of AnyDVD for PC)
Both are a little (more) difficult to implement
Regards,
Costin
Hello can you send it also to me?
Old Jul 7, 2009 | 02:51 AM
  #118
bizzlex's Avatar
RCostin lost me on that quote?? i did not understand exactly what he meant.
anyway..
has anybody succeeded unlocking the mmcs on the australian version??
Old Jul 7, 2009 | 09:33 AM
  #119
jhyatt1271's Avatar
Well after three trips to the dealership and two different units they finally fixed my MMCS. They replaced the whole unit screen and all just to fix that hard drive. I guess they can't just order a hard drive with the OS loaded on it from Mitsubishi. I'm not sure if I have the guts to try it again being as it took a month for them to get it fixed and the fact that this is my wifes car and I had to listen to that crap for a month. Good thing I didnt tell her I did it . Thanks for all your help guys.
Old Jul 8, 2009 | 04:04 AM
  #120
dernayka's Avatar
Good new jhyatt1271 . as for me, I received my unit with missing 2 cables: the DVD audio cable from the Rockford amp to the unit and the 7 pins cable that connects to the wire responsible for checking the speed and the Gero so that my sound system increases the volume as I speed up.
Do you know if there is a possibility to order it online or if the dealer can ship it over?
Thanks
