How to unlock MMCS
Old Aug 9, 2011 | 01:01 PM
  #271
Systemfloh's Avatar
Originally Posted by fatiprger
I ned help, can someone upload the file from mmcs hdd2 i have deleted plz.
i have 261EM
Witch file you need
BR
Tom
Old Aug 10, 2011 | 08:24 AM
  #272
fatiprger's Avatar
i think there was one file, on my partition HDD2 its nothing. can you see wich files are there and upload for me plz.
Old Aug 11, 2011 | 04:34 AM
  #273
WiValdiBB's Avatar
Partition HDD2 doesn't contains any data.
Please look into my thread too:
https://mitsubishiforum.com/forum/mi...ructure-37519/
Old Aug 11, 2011 | 10:15 AM
  #274
fatiprger's Avatar
Thank you very mutch, I thought on HDD2 are some file
Old Aug 12, 2011 | 02:26 PM
  #275
casanovacyp's Avatar
hi you can tell me where is the hdd becouse i open all unit pcs by pcs and i have big troble now pls help
Old Aug 13, 2011 | 02:31 AM
  #276
WiValdiBB's Avatar
Mitsubishi MMCS HDD removal guide
Old Aug 13, 2011 | 10:50 AM
  #277
thank you so much but my unit dont have like that my unit is mitsubishi NR-VZ800MCD i just want to use as dvd player but menu japanesee doyou know anything about this what i can make ?
Old Aug 25, 2011 | 02:36 AM
  #278
cristian_m's Avatar
Default outlander diamond dec 2009-uk version
hi ,i'm an outlander owner, they sold the car mid. dec. with maps from 2007...bargain?!?...the update maps cost @£149 ( better to buy mobile satnav and their will be 2 for the price). Anyway, i manage to get 2010 maps from torrente but the size is 13.4GB...how bi'll gone burn on dvd?...can anybody help me?
Old Sep 11, 2011 | 02:36 AM
  #279
chris180's Avatar
hey guys. im new to this and i wasn't sure how i'd start my own thread, so i'll just post the question i have up here.
I have a '09 Lancer VR platinum edition and im trying to fix the equalizer on my MMCS system. I've installed a JVC sub and amp and i cant get the Bass just right. I want to play around with the Band's and the Frequencies but not sure how to set them....can anybody help me??
Old Oct 8, 2011 | 12:09 PM
  #280
ceka's Avatar
Default Locked ... No passwd for hdd?
I've read a lot but I did not find any solution. Please help me!
I bought the outlander and I'd like to refresh the map's files.
-I downloaded the "Mitsubishi MMCS map 2010A M190"
-unmounted the HDD as described.
-Put it in the laptop (Dell Latitude D510) as primary, no another HDD or card attached.
-Boot from CD with the XBoxHDM boot disk
-After beginning of the booting a security screen comes up: "Dell INC. Hard-Disk #**77K3TWDMT-595B, the system primary HDD, is protected by a password authentication system. You cannot access data on this hard drive without the correct password. Please type in the password the press ENTER"
-If I type, (- I think it's normal - don't see any characters. -the keyboard is OK- It's not a hardware failure.) The password given, then Enter key. "WRONG PASSWORD" Two more time (wrong pass), then this screen disappear. But this is not a solution...
-If I bypass this described "password srcreen" --happens after 6 empty ENTER or 3 wrong password given, then IsoLinux booting starting and after selecting Locking/Unlocking (3rd) menu option then I got:
root@box-HDM:/1
after unlockhd -p B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEBAB2DFB19E8996 DFAA8C9A8DDFDF +<ENTER>
- Then the message: "No drive found on Primary Master! Shutdown, attach drive and try again..."
As I think the HDD must be seen for the system from the beginning of the booting. If wrong pass is given, it's not attached to the system. If I check it in the BIOS Setup, no primary HDD is detected.
(As I wrote, the disk is OK, and the system see that it's protected and has be to be unlock.)
-Does anybody know the HDD password?
The HDD is OK, if I put back into the car, it works fine.
I tried all combinations of these passwords:
- b2bab3bcb0dfacbeb1bbbedfb1add2cdc9cebab2dfb19e8996 dfaa8c9a8ddfdf
- B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEBAB2DFB19E8996 DFAA8C9A8DDFDF
first these then which are for the UM theoretically too
- b2bab3bcb0dfacbeb1bbbedfb1add2cdc9ceaab2dfb19e8996 dfaa8c9a8ddfdf
- B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996 DFAA8C9A8DDFDF
and:
-EMCL OASDN ARN2-16MUN va isUre
-MELCO SANDA NR-261UM Navi User
The system:
Loader-BLD-NR-261EM 1.09
Application 00.31.06
Navisub micro 00.30.00 089004
Map Data M110/AEU_07_200701B
HDD: Toshiba MK3029GAC HDD2198 R ZK04 T
PLEASE HELP.
