How to unlock MMCS
Otaku, thanks!
I will try this unlock key in few days.
How can I disasseble this unit? I'm not very good in such type of job, but I've already detached HDD by steps from this topic.
Will JM MMCS unit work, if I'll take an original image from HDD and then restore a EM image to it? My main need is to change the language to English, to extend FM frequency range and may be to restore TV function (now TV only plays sound, not an image)
ORIGINAL: Out2005
Otaku, thanks!
Otaku, thanks!
If they are merely daughterboards, then yes, you might be able to replace the versions.
If there are major baseboard, then probably not .
atb.
O.
I will write a result of this experiment (next week, 'coz unfortunately now I have "work" laptop - with 1,8" hdd inside; "home" laptop with 2,5" SATA hdd inside and my "travel" netbook, without ability to start-up from CDs or USB.
I just need simple laptop with IDE 2,5 hdd and CD-ROM
ah..
heh ..
yeah - forgot to do the byte-flip didn't I..
well - just extracted the 2 keys from the JM bootloader
B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFAA8C9A8DDFDF
B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFB29E8C8B9A8D
take your pick..
atb.
O.
heh ..
take your pick..
atb.
O.
Sorry my english is not good. I unlocked HDD from by MMCS. Data of maps is in first partitions (20GB). I have EU maps 2006-1 a little old. If you need image data and particions of HDD please tell me and possibile send to you.
Originally Posted by rcostin
Hi everyone
As you may know, Mitsubishi released a map update DVD available for Europe. Unfortunately, the update works only with a hardware key. Fortunately, there is a method to bypass this if you are willing to take the hdd out of MMCS. You will need:
1. a computer running linux with 45G of free disk
2. a copy of the original DVD
Procedure (long version):
1. unlock the MMCS' hdd as described here (https://mitsubishiforum.com/forum...ad.php?t=25583)
2. copy the files hd1.xxx from DVD to disk
3. rename all hd1.xxx as hd1.xxx.gz
4. decompress all gz files
5. join all resulted files in a single large file (~20G)
6. mount it in linux on a folder (in /mnt for example)
7. attach MMCS' disk to the linux box and copy all files from /mnt to the partition containing the maps (you may overwrite the existing files)
8. turn off the computer and moutn the disk back in MMCS
The short version:
1. download the archive from ftp://194.88.148.1/ (username: maps pass: mitsubishi)
2. extract all files to the MMCS' disk partition containing the maps (overwrite)
NOTES
As usual, you are the only responsible of what you do with your disk and data. If you ruin it, is only your fault.
More to come
Hi everyone
The short version:
NOTES
More to come
greetings to all and congratulations for your "discoveries"
i am new to this forum and i could rally need some help..
i own a new pajero with mmcs (loader BLD-NR-261EM V1.09)
i red all posts very carefully and followed step by step the instructions given by rcostin at the very first post :
i removed the hdd and i made a bootable cd containing xboxhdm. Then i connected the hdd to my laptop (single drive) and booted from the cd with option 3. with linux. so far so good ...
i run the unlockhd command -p (including each and every password i found in this forum)... but....zip, niente nothing ! everytime the result is the same :
HDD serial number : "something"
HDD firmware revision : "something"
HDD model : TOSHIBA MK3029GAC
Security supported : Yes
Security enabled : Yes
Security locked : Yes
Security frozen : No
Security count expired : Yes
then i also rub the fdisk -l command and....of course nothing happend!!
any help and advise will be much appreciated!!
thank u for your time and i will be waiting for an answer (if any)
Good evening! I'm from Russia. Unfortunately, I do not know English.
We also have a forum, MMSC.
The main theme - no maps of Russia. But before we deal with the cards, we want to install Russian language in the MMSC of European and Japanese versions. My Pajero installed NR261RM, there are Russian. I would like to know is it possible?
Thank you!
Thank you!
