Internal heater
Hi all..
Can any member tell me where to find the heater sensor (and what it looks like) on a 2008 Outlander 2.2 Di-D.
My interior heater does not get warm unless I turn it right up to the max. This has only recently started to occur so I am guessing there is an issue with a sensor somewhere.
thanks
thanks
if your engine is reaching temperature and holding it okay...then I can only think of two other possibilities.
- your heater core is clogged/congested
- the blend door is stuck in default position...which would likely be a vacuum leak, which would give you problems with which vents the air is coming out of.
unless you have some sort of automatic heat control, there wouldn't be a "heat sensor".
MontSport2000LS
11
Feb 23, 2007 12:56 PM
p4c0
Feb 22, 2007 06:36 PM
97GSpower
Dec 9, 2005 10:46 AM
