Ipod connection
Old Jan 14, 2009 | 07:18 PM
Helicopter_red's Avatar
Default Ipod connection
Hi does anybody know if it is possible to connect an ipod to an outlander 08 equippe uk model (has single disk cd player) i have heard about leads available but can never find any info relating to this also does anybody know if you can use the controls on the higher spec steering wheel to control the same radio
many thanks
Old Jan 15, 2009 | 02:18 AM
jsrd's Avatar
Default RE: Ipod connection
You need an adapter that is connected in the back side of your radio, in the port that seems S-Video. P/N MZ608561, or Kenwood KCA-iP500 iPod® Control Interface:
NOTE: this adapter is only for MMCS
Another alternative is that you obtain a audio/video adapter cable (iPod/RCA terminals) to connect to input on rear central console and to listen through AUX input . . .
Old Jan 15, 2009 | 05:29 AM
ash's Avatar
ash
But will the Kenwood version work with the no Sat Nav single Disc Unit? If it does, I think I will get one, not cheap at around £65.00.
Old Jan 15, 2009 | 03:41 PM
abrcrombe's Avatar
jrsd -
Have you used that kenwood adapter? Does it allow you to charge the ipod? Does it allow you to control the playback with the onscreen and steering wheel controls?
Thanks!
Old Jan 15, 2009 | 04:45 PM
mitsupartsman.com's Avatar
there is no din connector on the back of the cd player for the kenwood model to hook upto.
Old Jan 15, 2009 | 06:09 PM
jsrd's Avatar
I agree mitsupartsman [sm=smiley20.gif], I check in the rear side of the CD-radio and there is no such connector, so for Helicopter_red , the second option would be for him. I placed a commentary to clarify this
abrcrombe, I do not have this accessory. The kenwood adapter that I commented treated in the forum and azchipka obtained the model. I remember that he said that did not work the controls in the steering wheel, but I need to find in where its. . .
Old Jan 16, 2009 | 10:20 AM
ash's Avatar
ash
ORIGINAL: jsrd
Don't think it will as the UK model doesn't have the connector behind the centre console.
Old Jan 16, 2009 | 11:30 AM
lapulapu's Avatar
Does anyone have a picture of where this Kenwood KCA-iP500 plugs into the MMCS?
Old Jan 22, 2009 | 10:27 PM
aussie_outlander's Avatar
Mitsubishi Australia installed a connection at the back of my single unit. I just connects to the output of the iPod, so no charging and it uses the aux to play.
mhc1990
Jan 30, 2021 12:00 PM
dbblackdiamond
Sep 28, 2010 08:03 AM
Flutie84
Jun 5, 2009 12:02 PM
mrey16533
Jan 20, 2008 06:23 PM
ajustator
Nov 28, 2007 04:18 PM
