Low coolant. And what type of coolant?
Old Jan 10, 2010 | 07:45 PM
ruski's Avatar
Default Low coolant. And what type of coolant?
Hi all.
My 2008 Outlander (V6) is about 1 year old.
I never thought to check the coolant level before. I don't know where it was when I took delivery of the car, so nothing to compare against.
I just decided to check my Overflow tank and the level is quite a bit lower than Low, with cold engine.
And it went up just a little bit with warm engine, but still doesn't reach the Low mark.
I figure I can add some coolant, except I don't know what type. Mitsubishi manual says to use Mitsubishi coolant (figures), which is kind of vague.
Is there a coolant like Dex-Cool that I could find at an auto parts store that will work? Will it be OK to mix that with the existing coolant?
(My Pontiac GTO takes Dex-Cool and it cannot be mixed with any other type of coolant or else)
Thanks!
Old Jan 10, 2010 | 08:09 PM
rip14's Avatar
Mine never gets above low. Never has, never been a problem. Check the actual radiator (when it's cold).
Check out this thread:
https://mitsubishiforum.com/forum/sh...ad.php?t=34741
Old Jan 10, 2010 | 08:56 PM
azjake's Avatar
Rip14 is right, check the coolant when its cold. Coolant is sucked out of the overflow tank as the engine heats up, and then goes back into it as the engine cools. Thats why you should check it when cold.
My owner's manual says "Long Life Antifreeze Coolant or an equivalent". I have a 4 cyl ES, but I would think the V6 would use the same coolant.
Old Jan 10, 2010 | 10:05 PM
ruski's Avatar
that's right, mine says to use "long life antifreeze or an equivalent", I think there is another spot where it says to use Mitsubishi coolant for best results
So which coolant do you guys use?
Also the radiator cap check is a little strange since the cap is not on the radiator like most other cars, but instead the cap is on the radiator hose.
Old Jan 11, 2010 | 02:57 AM
jsrd's Avatar
Time ago the level was low in my Outie too, I went to dealer and they filled it without cost for my. A thing, don't mix different antifreeze types. . .
Old Jan 11, 2010 | 10:55 AM
ruski's Avatar
The way dealers are here, they will want to sell you a brake job if you show up asking to fill up the coolant
Old Jan 15, 2010 | 01:29 PM
bnilguy's Avatar
i had to add a bit of coolant as well. I just used Prestone all makes (non-Dexcool)
Old Jan 15, 2010 | 04:07 PM
ruski's Avatar
Old Dec 30, 2010 | 01:25 PM
ruski's Avatar
Old Dec 30, 2010 | 05:32 PM
ccernst's Avatar
I paid 12 bucks at a NAPA for concentrate Peak global lifetime coolant
acuz604
Apr 24, 2015 02:22 AM
3000gtizzle
May 23, 2007 12:23 AM
gsnoddy
Mar 27, 2007 10:47 PM
mobetta
Oct 3, 2006 08:46 PM
mattsride
Mar 3, 2006 09:29 AM
