Mitsubishi Trailer Wire Harness Problems
Old Dec 15, 2009 | 07:09 PM
ikeandtike's Avatar
Default Mitsubishi Trailer Wire Harness Problems
Having problems with a newly installed OEM Wire Harness
Everything is hooked up correctly, but it isn't working. There is appx 12v (I believe volts) going to all 'ports' on the harness...but It isn't transferring to a trailer? also, when I press the brake or turn indicator lights on, there is no change in the Volts. There is also current going to the harness when the outlander is off.
Does the mits. computer need to be told there is a trailer wire harness installed?
Old Dec 28, 2009 | 11:31 AM
jbatchelor51's Avatar
I had this problem. The grounding is awful for the electronics box you mount above the wheel well. I had to scratch off the paint and check the ground before attaching the ground wire.
islandrider
Aug 11, 2020 06:07 AM
milliesdad
Apr 7, 2011 06:53 PM
Skywalker636
Apr 18, 2009 12:04 PM
mld211
Sep 24, 2008 07:25 AM
tusokuga
Jun 23, 2006 03:42 AM
