Oil dilution and failed turbo 2016 outlander diesel
Old Oct 2, 2023 | 12:30 PM
AMS100's Avatar
Default Oil dilution and failed turbo 2016 outlander diesel
Had a failed turbo and oil dilution in the last few days. Waiting for a mechanic to look at it. Symptoms, whistling sound, over about 80km distance of easy driving resulted in loss of power and metallic noise from turbo, turbo shot. Strangely no warning lights on dash for dpf or anything else or limp mode…. Oil level increased in engine was between full and x mark when checked and 30-40km later was slightly above x, when turbo went… 140,000km and full independent service about 8,000 km ago with oil change….. the main feedback to date is possibly dpf (but no lights on dash ever for this) or injector…. Felt for a while that engine sound was a bit muffled when being driven, ie listening to it when someone else was driving the car at low speeds…. Any pointers would be helpful…. Most likely suggestion at the moment is dpf causing back pressure on turbo and Regen malfunction causing diesel in oil and turbo bearing failure
Old Oct 2, 2023 | 12:50 PM
AMS100's Avatar
Other possibility mentioned was potential problem with oil pump….
Marks73!
Dec 3, 2023 09:55 AM
Ricksatluz
Nov 11, 2021 02:41 PM
Mambobob
Aug 2, 2017 04:32 PM
superpete69
Mar 25, 2012 07:33 PM
99clipsgst
Sep 16, 2005 03:03 PM
