Rim Question for Winter
Old Dec 23, 2008 | 08:00 PM
ShortyRider's Avatar
Default Rim Question for Winter
Looking to get some winter rims, the black steelies, or just some used rims.
What do I need to know for the rims before I go hunting for them??
I have 18"s now, but I want to just put 16s on for winter. The LS tires are 215 70 16, so I'm looking at somewhere there.
I know they need to be 16", 5 X 114.3, Offset is 38mm, and the width of the rim is 6.5m...Anything else
Also, does it matter how wide the rim is, the LS stock rims are 6.5, but can I go less or more? Also, what is the offset of a rim and the center bore??
Thanks
Old Dec 23, 2008 | 08:22 PM
Canuck's Avatar
Default RE: Rim Question for Winter
Don't forget the tpms sensors
Old Dec 23, 2008 | 08:41 PM
Yep the TPMS will be removed for the summer along with the rims.
They are wireless right? Therefore removing the stock rims takes care of the TPMS going away? Do I need to re-set it when I put back the stock rims on??
Old Dec 25, 2008 | 12:59 PM
9LIVEZ's Avatar
Center bore is 67.1
FYI, I used a set of Gen 1 Eagle Talon wheels on my Outlander. Bolt pattern and center bore are identical. They are 16"x6" and work perfectly with my 215/70R16 tires. I have 3 extra rims for sale. If you are local (Ontario), PM me for details.
Old Dec 26, 2008 | 01:14 AM
Canuck's Avatar
Removing the tpms from the wheels means you will have a tpms warning light on your dash all the time.
newoutlanderfan
Nov 26, 2012 07:32 AM
armymen
Sep 9, 2011 12:29 PM
pwrhouss
May 16, 2007 08:12 AM
BLkOUT01
Feb 10, 2006 11:23 PM
mysterio2099
Nov 19, 2005 08:19 PM
