Thinking of Buying a 2015 Outlander
Old Apr 5, 2018 | 10:31 AM
MrMitsu's Avatar
Originally Posted by leftoverture
Thanks, Mr Mitsu. The only negative about the V6 is having to change the timing belt. Seems like with any Outlander I have to choose between that and the potentially questionable reliability/performance of the CVT. Not an easy choice. But are you saying that if I plan to tow even occasionally, the CVT might not be the best choice? I'm still continuing to look at alternatives like the VW Tiguan and Jeep Cherokee. Guess it's a good thing I'm not in a hurry.
How so? Quite a few legendary engines are timing belts. It depends on what you plan on towing, I have already towed a Jay Flight SLX trailer and some smaller trailers with ease. The maximum tow weight of the 3.0 is 3500 LB ( with trailer brakes) the 2.4 is 1500.
As a general rule I make sure what ever I'm towing is -15% or greater then the maximum weight so the engine is not running at full capacity. Just because you can doesn't mean you should.
Old Apr 5, 2018 | 09:32 PM
leftoverture's Avatar
The cost to change the timing belt. It ain't cheap unless you can do it yourself and even then, it's not an easy job. I drive a lot so I'd be incurring that expense at least once every 3 years. For that reason, I won't buy any car with a timing belt, except my old Miata which I don't drive that much and I can change it myself.
Old Apr 5, 2018 | 10:41 PM
MrMitsu's Avatar
Then it would seem you may have not needed our input. 😁 Good Luck on the purchase!
Old Apr 6, 2018 | 05:55 AM
I was never considering a V6 model. The ones I have been looking at have the 4 cylinder which has a timing chain.
Old Apr 12, 2018 | 08:23 AM
homestead367's Avatar
My CVT wines a little. The 2.4 is way underrated in what it can tow.
Old Apr 12, 2018 | 11:38 AM
Do you tow regularly with yours?
Old Apr 12, 2018 | 12:06 PM
Not really. It had a hitch on my 2013 Outlander which was the 2.4 CVT FWD. I had to rent a uhaul trailer which are 1500 lbs empty then throw 1 ton of dirt in it (3500lbs total). It pulled it but was not happy with me. The second time I had the same trailer with a bunch of furniture. Pulling a ton was not a problem (2000 lbs). The biggest issue I had was mine was it was front wheel drive. I have not tried towing yet with my 2015 awd. I would assume it would do better since the back tires can provide traction as well.
quills
May 13, 2016 07:43 PM
300winmag
Mar 19, 2011 11:03 AM
Sinbad
Nov 1, 2010 09:16 PM
Murvalous
Sep 20, 2007 11:40 AM
Mak3
Jan 15, 2004 12:21 PM
