TPMS tool
Old Aug 17, 2025 | 10:23 PM
  #31
Jonathan Truong's Avatar
Originally Posted by sevensandeights
Thanks again. Last questions (I hope!):
My recommendation to the tire shop will be to utilize the autocreate procedure on the new Autel MX sensors with them uninstalled. After they are configured with autocreate, can the relearn procedure also be performed with the sensors just sitting on top of the tires, but not actually installed? If so, will the current sensors interfere with this process if they are still installed in the tires?
Ideally, I would like them to do the autocrate process and the relearn process with the Autel sensors just sitting on top of the tires and the current sensors in place inside the tire. This way, they'll know the Autel sensors will work and can then dismount the tires from the rim, take out the current sensors and install the newly programmed Autel sensors.
Yes, it can.
Old Aug 18, 2025 | 01:39 PM
  #32
sevensandeights's Avatar
I have an appointment at the tire shop this Wednesday. I stopped by today to confirm some things. The current sensors are Autel MX sensors. The shop uses an Autel Maxitpms TS508. So, based on your previous recommendations, I suggested they deflate all the tires to zero PSI and perform the autocreate process with the existing sensors. I also sent them a link to this discussion.
Any other suggestions?
Old Aug 18, 2025 | 06:35 PM
  #33
None at this point.
Old Aug 20, 2025 | 10:33 AM
  #34
Unfortunately the tire shop didn't have any luck with the autocreate process so had them remove the sensors all together.
Old Aug 20, 2025 | 01:07 PM
  #35
That's not good.
boogunoogun
May 6, 2018 04:30 PM
OutlanderGT
Dec 12, 2013 10:59 AM
PeckyPeck
Oct 8, 2013 10:15 AM
Fisherman
Nov 1, 2007 09:04 AM
Fisherman
Aug 1, 2007 11:21 AM
