Transfer case and differential oil change
Old Nov 10, 2017 | 05:43 PM
kev994's Avatar
I did not change the washers. They haven’t leaked.
Old Nov 11, 2017 | 05:34 AM
ccernst's Avatar
same here....no washers, no leaks. And you don't need Mitsubishi oil....any 75w90 would be sufficient.
Old Dec 20, 2017 | 06:29 PM
Outlander1085's Avatar
Default Transfer case and differential oil change
I've got a 2016 Outlander, parts guy gave me 90 weight gear oil for both transfer case and rear differential. My owners manual says 80 of both but parts guys says it has changed and that's what they use now.
Thoughts?
Old Dec 20, 2017 | 08:04 PM
kev994's Avatar
Depends on your climate. If it gets below freezing you’re way better off with a multi-weight. I think I used Redline 75w80 and 75w90 but 75w90 would work for both. Check your manual but I think it needs to be GL5 Hypoid gear oil.
Old Dec 20, 2017 | 08:34 PM
Like I said I bought mitsubishi gear oil from mitsubishi parts counter. They gave me 90 for both. I'm in the Chicago area. I'm curious as to why mitsubishi changed this. Were they having problems with the 80 weight?
Old Dec 22, 2017 | 10:07 AM
BTW with only about 29k the front transfer case fluid was pretty dark and dirty. The rear wasn't nearly as bad. We do a lot of family trips so I plan on changing these fluids once a year as preventive maintenance.
Old Mar 23, 2019 | 03:28 PM
Rsd's Avatar
Rsd
Originally Posted by nesser
TCP, can you confirm these are the transfer case fill and drain points.
My 2009 seems to have the fill as a 17mm bolt and the drain as a 10mm hex head - only had a 3/4" (9.54mm) hex from a previous vehicle on hand so didn't do the service.
I didn't see any 22mm heads unless you are talking about the small outer rim of the drain fastener.
This image looks like the description in the service manual section 00-67.
This is also correct for 2016 sel 3.0l v6. You can use a regular socket and ratchet for the fill plug if you use an extension.
Old Jun 9, 2019 | 01:50 PM
Milen's Avatar
Default When differential oil need to be change for Outlander 2016 SE
I have Outlander 2016 SE ,I ask Mitsubishi dealers when differential oil need to be change one say 30000 other 60000 mills. In the manual don't say clear when too. May I have opinion on this subject from the forum.
Thanks
Old Oct 13, 2020 | 12:10 PM
kev994's Avatar
Bit of an update: Redline faired much better than the factory fill. I had ~95,000 kms on factory fill, the diff looked awful, kinda grey. I put 70,000 on the redline, diff was a bit darker than the new stuff, transfer case looked pretty similar to the new stuff. Redline seems to have changed their recommendation, I had a partial qt of 75w90 marked transfer case, they now recommend 75w85 for both.
The transfer case fill bolt is not bad if you have a socket and ~5 inch extension. A pump is the way to go to fill these. I think I got mine off amazon, maybe from redline online.
qenex
Jun 17, 2022 08:33 PM
mrlimey
Jan 26, 2018 11:12 PM
ccernst
Jan 24, 2015 07:52 AM
rayf01
Mar 4, 2014 03:00 PM
klas
Mar 14, 2012 09:56 PM
